throttle body ?
Old Dec 28, 2003 | 07:02 PM
Maree's Avatar
Default throttle body ?
Hey guys are the 5.7 f-body throttle body and a truck 5.3 throttle body the same? What are the differences? Thanks in advance.
Old Dec 29, 2003 | 03:54 PM
WILWAXU's Avatar
The truck TB's I've seen look very simular to ours. They have different springs and coolant tube locations.
Old Dec 29, 2003 | 04:26 PM
jimmyblue's Avatar
Moderator
I used a truck core for my TB home-porting. However
I think I've read about some 5.3s (like the SSR) having
the drive-by-wire throttle, so best get a picture if you
plan to transplant from a non-identical donor.
Using the truck core I had to swap PCV fittings and I
bypassed the coolant lines anyway (so I cut them
and the boss they sit in, clean off).
Old Dec 31, 2003 | 10:24 AM
Old SStroker's Avatar
The throttle cable cam is different for the cable operated ones, in addition to what WILWAXU said. Trucks have an orange return spring. Yep, some are throttle-by-wire.
