u bolt on clutch master cylinder
Old Feb 25, 2010 | 07:12 PM
bigwill12187's Avatar
Default u bolt on clutch master cylinder
Hey guys,
So today I was trying to take my clutch master cylinder out and I took everything out and was going to put the master out and it does not come out. It looks like that u-bolt is in the way. Does anyone have any tips on how I can get this out like is there anyway to take that u-bolt out. Thanks everyone.
Old Feb 25, 2010 | 07:37 PM
6.0 silverado's Avatar
This would probably be better off in the manual trans section, but you need to remove the u-bolt first. It can be a pita to get out, but it comes out.
Old Feb 26, 2010 | 07:38 AM
Thanks,
I'll try to get that out this weekend then.
Old Feb 26, 2010 | 10:18 AM
Justins00ss's Avatar
Yeah the U bolt comes out with some patience. Make sure you take off the star washers that are attached to it once it comes thru the fire wall. You might have to get a pair of dykes and just cut them off. Getting it all back together is the fun part.
Old Feb 26, 2010 | 06:15 PM
Zero4488's Avatar
Restricted User
Agree'd with the previous posts....double check the star washers and then just take your time and remove it....and if you think this is the hard part wait till you try to put it back together....
Old Feb 27, 2010 | 08:14 AM
Yea lol great and I looked at it yesterday and no star washers that u bolt is just stuck and wont some apart from the master cylinder. Anyone have any tips or tricks that I can do?
Old Feb 27, 2010 | 10:29 AM
Really?? Thats odd. The star washers are located under the plastic that covers the studs on the inside of the car. I would double check to make sure that you didnt miss them. It took me a little while to realize I had the same issue. If thats not the case then maybe just use something to bang it loose from the inside of the car. But I am almost positive that those star washers are still holding it in.
Old Feb 27, 2010 | 10:32 AM
98LS16T56's Avatar
it can be done, but is a pain in the ***** to get back in, if you think you can get it back in by yourself, you are wrong, I spend 1 hour tring to get it back in bymyself before I had to have my brother help me line up the holes
Old Feb 27, 2010 | 11:03 AM
I did manage to get mine back in by myself but it took over a 1hr too. Just keep at it and you will figure it out.
Old Feb 27, 2010 | 11:12 AM
Yea I think there are no star washers because I have one side out of the hole and that u bolt is like stuck or something on the master lol like I said Im gonna mess with it tomorrow im so close to being done need to do that drill mod put the slave in tranny back and some little **** and ill be done.
Old Feb 27, 2010 | 02:49 PM
Viper's Avatar
At this point banging on the end still in the car is an option. The better option is to get the end that's out back in; you want the u bolt coming out straight on. Bang a little on each side till it's out.
Old Mar 2, 2010 | 05:33 PM
Ok I worked on it sunday I took a flat head and pushed on the master on the fire wall it came off took me two min.. no joke to get out. Then i did the drill mod and put it back in by myself and that was like a five min. job. lol. Thank for the help guys.
Old Mar 21, 2010 | 04:18 PM
ozzman98's Avatar
was ur master really easy to take out? i have my u bolt off but the master just wont come all the way out. i keep twisting an pulling it but it keeps gettin hung up on the steering or the header. how did u get urs out??
Old Dec 25, 2012 | 06:58 PM
Wrench7777's Avatar
If the clutch peddle sticks every once and a while does that mean it's the master cylinder. Or the slave. It sounds like when your holding the clutch peddle in, it sounds like it's releasing down by the tranny. Any thoughts about that. Thanks
