carb questions
Old Feb 26, 2010 | 12:06 AM
98 z28 mullins's Avatar
Exclamation carb questions
ok so im getting ready to go with a 6.0 truck motor and im gonna run ported 5.3 heads with a custom grind comp cam 150-200 shot of nitrous and a victor jr intake with a eldebrock 750 cfm carb
what i need to know is will the 750 over fuel or under fuel that setup and what else do i need to get running with this setup besides the timing control module
Old Feb 26, 2010 | 12:10 AM
oh yeah forgot to mention it will prolly be headers only for exhaust cause im making a drag car out of it
Old Feb 26, 2010 | 07:24 AM
bump guys if anyone know this stuff let me know cause im not familiar with this setup yet and i will be going with the biggest lift cam i cam with out getting piston slap
Old Feb 26, 2010 | 07:28 AM
white mayhem's Avatar
I'm building a 408 with about 520 to the wheels and they speced me out a 750 so that might be a little to big for a 5.3. Best thing is to call and have them spec one out that would be correct for your setup
Old Feb 26, 2010 | 07:32 AM
butler's Avatar
I run a holley 750 double pumper on the same intake, 383. For a 5.3 go with a 650 the motor won't need the 750. Stand alone fuel cell and pump for your fuel on the nitrous. What's it going in? Fuel pressure on the carb shoud not go over 7 psi or under 5 psi. Another thing the motor will only pull so much air even if the carb is bigger, but getting it dialed in will be more difficult with the bigger carb.
Old Feb 26, 2010 | 07:51 AM
Nabdrill's Avatar
That 750 should be the right carb for that application. What I would rec. is to give Edelbrock a call and talk them thru your set-up. I'm sure that they would be happy to give you an initial set-up for that carb... and that's free.
If you're planning on using your factory fuel pump then you'll have do some modifications to your system and install a regulator.
Old Feb 26, 2010 | 09:55 AM
TooLateVTEC's Avatar
READ THE THREAD GUYS, hes going to be running a 6.0 with ported 5.3 heads LOL.
I'd say that may be alright.
F Edelbrock....who you really need to call is Patrick James at Pro Systems. He knows his **** when it comes to carbs. He made a 1250 dominator for our 565 that was spot on right outta the box, we just had to make minor jet changes for weather. Even if you dont send it to him, he could help you set it up and I bet he knows more than 95% of the carb people at Edelbrock.
My opinion.
Old Feb 26, 2010 | 03:31 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
You'll need the MSD 6010 box, a fuel pressure regulator, fuel pump, throttle cable bracket, and a few other odd and ends
Old Feb 26, 2010 | 04:49 PM
butler's Avatar
My opinion.
Wow that's a huge motor. I mean a 6.0. How many motors actually need all the cfm the carb is rated for? But it does depend on how high he is going to spin it. Call the guys at Holley, too.
Old Feb 28, 2010 | 11:18 PM
prolly nothing over 7000 rpms
Old Mar 1, 2010 | 08:18 PM
LS_10's Avatar
I have a LS1 with head work done vic jr. decent size cam and i'm running a AED 750HP-HO and it loves it
Old Mar 1, 2010 | 08:45 PM
Z28/2002's Avatar
same carb I'm running
Old Mar 4, 2010 | 11:26 AM
5_02ls1's Avatar
mike when you get ready to put the car together ill help you pick out parts...edelbrock carbs are ok on a mild street car setup,but for a drag car id stay away from them...
fuel system will be simple to convert over...a holley blue pump and regulator cost under 100 bucks...all ill have to do is pull your sending unit and remove the factory pump and regulator...no big deal...
we will figure it all out when the time comes...
Old Mar 4, 2010 | 12:11 PM
ZONES89RS's Avatar
In-Zane Moderator
I have run a 750 on a stock 305 SC, as long as you tune it right it will work fine, but anything that has a cam and spins to 7000 RPM, a 750 is WAY easier to tune. A 750 works great on a 5.7 small block and will be great on a 6.0 GEN III, i am going to be running my 800 CFM holley i built myself on my 6.0.
Edelbrock sucks for carbs as far as my opinion goes, get a holley and dont look back, ease of tunability and makes more power.
Old Mar 5, 2010 | 07:31 AM
ok so it sounds like i really need to stay away from an eldebrock carb so what are my other options as far as that goes
Old Mar 5, 2010 | 12:31 PM
5_02ls1's Avatar
HOLLEY lol...
Old Mar 5, 2010 | 10:06 PM
molsen's Avatar
If you are making a drag car out of it I would go holley 750 Double Pumper w/o choke tower. That will give you a nice power. I ran that on the old 23 degree 383 small block. Great at the track, lousy on the street. My motor liked lots of fuel and that sucker supplied it all the way through.
