No clutch pedal pressure!
Old Mar 8, 2010 | 07:06 PM
mello03's Avatar
Default No clutch pedal pressure!
Well, I changed the oil and was doing some other stuff to the car and decided to bleed the clutch fluid like I have done about a half dozen times before. I have an aftermarket remote bleeder that runs down by the front drivers tire. It has a speed bleeder on it so I attached my speed bleeder bag, open the bleeder and have my girl start pumping the pedal while I am watching the reservoir. Never let it go dry. So finally when the fluid is nice and clean I close the speed bleeder and no frickin pressure. What could it be? I am assuming I got air in it somehow. Maybe the speed bleeder has gone bad? I am screwed now because the car is in the driveway and I can't get it into gear! Do I need to gravity bleed this or go buy something that can bleed the clutch with power like a vac?
Old Mar 9, 2010 | 01:45 PM
jimih941's Avatar
sounds like you could have gotten air in it... try completely bleeding it again and see what happens
