TPS problems
Old Mar 9, 2010 | 02:45 AM
Tbennett13's Avatar
Default TPS problems
My car started idling very high around 1,800 and throwing a check engine code. so I took it to nappa and I was throwing a TPS code and then it clicked.. a buddy said he was going to clean my intake MAF and such while I Was waxing the car. welll long story short he used WD-40..... :Facepalm:
So my question is do I need to replace the MAF or just the TPS?
where would I get just a TPS?
would it hurt to drive around with the TPS sensor replaced?
Old Mar 24, 2010 | 12:00 AM
Tbennett13's Avatar
anyone?
Old Mar 24, 2010 | 01:01 AM
brian_rs/ss's Avatar
hmmm did u try getting all the residue off of the MAF?
Old Mar 24, 2010 | 01:28 AM
LS1MCSS's Avatar
Get some cleaner made for cleaning a MAF, and tell your buddy to stay the hell away from your car.
http://www.crcindustries.com/auto/co...x?S=Y&PN=05110
Old Mar 24, 2010 | 03:29 AM
kmracer's Avatar
PAH! owned. clean the maf, and check the tps voltage. theres a walk through around here somewhere. could just be out of adjustment.
Old Mar 24, 2010 | 03:37 PM
mrx8200's Avatar
I'd try using MAF cleaner. Cleaning it should solve the problem, but if the hot wires came in contact with anything you may have to buy a new MAF. This sounds to me like a MAF issue. WTF was he doing with WD 40?
Old Mar 24, 2010 | 03:47 PM
take a can of WD, spray it down friends throat, ask him if he likes it....win?
Old Mar 24, 2010 | 03:49 PM
CranMaro99's Avatar
I was going to say the same thing!
Old Mar 25, 2010 | 02:41 PM
mrx8200's Avatar
+1 for spraying the WD 40 down the "friend"'s throat. If you don't know what you're doing then stay away from the car.
Old Mar 25, 2010 | 02:48 PM
Joshiedoom's Avatar
Clean the maf and TB but most likely if the TPS sensor is throwing a code it is bad as it is reading the sensor itself, not throwing a IAC/MAF or idle code.
They are cheap and a 5 minute fix.
