Ac removal?
Old Mar 11, 2010 | 04:22 PM
99T/AVert's Avatar
Originally Posted by conan
I think he made the plate him self. You could take the OEM plate and trace it on a sheet of metal and cut it out with a angle grinder.
All cool, I got a Dremel
Old Mar 12, 2010 | 08:20 AM
SLOW30th-TA's Avatar
You can buy the AC delete panel from BMR for $80.
http://www.bmrfabrication.com/misc/FP003.jpg
Old Mar 12, 2010 | 01:07 PM
99T/AVert's Avatar
Thank you for the info but geez thats a little steep for a piece of sheet metal.
Old Mar 12, 2010 | 01:12 PM
bww3588's Avatar
you cant keep your heat with that pannel. plus you have to pull the dash to install it.
Old Mar 12, 2010 | 01:15 PM
01'SSLSX's Avatar
couldnt u just drill/cut for heat hoses?
Old Mar 13, 2010 | 01:27 PM
bww3588's Avatar
that pannel will not work with heat because you have to take the entire heat/ac box out to install it. it goes on the inside of the firewall. it would be pointless to go through all that work just to install when you have to cut the box anyways. now if you were removing heat and ac all togehter it would be a different story because your already going to be removing the dash.
