Failed smog CA for TB Bypass
the coolant in the tb is used to heat the air faster going into the engine. this affects emissions if moved. i think its bull. i pased witth a fast 90 90 2 years ago bro. that guy was probably wanting money to pass you.
+1... I passed with TB bypassed.
At a test only station.
And I had red caps plugging off the ports on the TB.
Twice (2007 and 2009).
One the test it says: vacuum lines are altered. I hope the CA referee takes my side and that I can file a complaint with the CA smog *****. There needs to be some accountability on behalf of the testers. It was a full repair shop. He was looking everywhere; even the wheel well. He must of spent 20 mins snooping around. I lost $59.99 but I found out that referees only charge $8 (cost of paper work) because the state is paying for the test.
I did this mod to my Yukon a couple years ago or so, and it just failed the SMOG visual inspection at a TEST ONLY center here in northern CA: "...VACUUM hose missing at throttle body". The @#%!-ers barely spoke English, so perhaps they think VACUUM=COOLANT. Who knows.
I can't knock them for taking their job seriously. But I'd be lying if I said I a swift forearm to their nose wouldn't be fun.
I'd rather not post the shop's address on the internet. But if you really want it, PM me.
Here's what I read from another site: If you read the EPA emission rules they say you can't tamper with any part of the syetem as it was certified. Although he's ****, and was stretching it a bit, he's right by the letter of the law. I'm not taking his side, but a friend of mine works for DE DMV. Our rules are quite a bit relaxed compared to what you have to deal with, but he said he can fail almost any car he wants to if he's in the mood or the owner's a jerk.
I'd argue that if a shop couldn't tell the difference between a coolant line and a vacuum line, they likely weren't competent enough to do state inspections. The throttle body coolant line has nothing to do with emissions, so it wouldn't fall under the "no modification" rule, regardless of how **** they are about enforcing smog rules.
That tech sounds like a punk. Glad I'll have my license in sept. Sounds frustrating I hate mfers like that. I think its about the thottle freezing on the freeway in cold climates, what an ***. I'd just hook it back up for 10 min and leave that guy a burnout on his face. Throw some porcelin through his window.
it is an emissions device. Having that connected heats the air as it comes into the engine. I forget what pollutant it causes a drop in.
Its a similar pupose as the exhaust heat risers on old carb'ed motors.
It has little (if anything) to do with freezing. By the time the coolant is warm enough to prevent freezing the engine itself will be radiating heat.
It does suck that they failed you for that. and Im guessing its listed as a vacuum line because their computer only excepts certain reasons for failure. and "throttle coolant line" isnt one of them. I hope you can get this straightened out without having to fork over another 60 bucks.
But then again isnt that the point of the whole CARB crap? Kill the hobby and rise money for the state.
this is an old thread.
smogging in CA is bullshit sometimes. after trying to keep in line with CARB i gave up.
my car was in stock form with all "readiness" tests in the green (i actually scanned it to make sure) when i took it to get it smogged. i paid they guy and then he tells me it failed as SOME of the "readiness" tests were not in the green. i called his BS and he charged me extra to put the car back on his scanner so i could get a print out... lo and behold, they're ALL in the red as if he had just cleared them... then he said to drive the car around a bit and bring it back for another smog at 50% off - that it should pass... very shady. i got pretty nasty with him, but he seemed numb and used to it. i put up negative reviews on google and more followed as it seems he does it a lot. over the years, i've had similar things happen with other cars and for all i know, they pulled the same ****.
after that, i gave up on smogging it - see mods in sig. it isn't a daily driver, so i'm doing my part to keep the air clean. CARB is a waste of tax dollars IMO.
#32
The only thing the TB coolant lines would DO would be to help the engine warm up quicker. It's like the warming air ducts on the older engines with the drier hose hooked the the exhaust manifold heat shield.
#33
The EGR is designed to reduce nitrous oxide emissions, but the throttle body coolant line isn't going to do anything for emissions. If anything, you would want an actual cooler (not hot coolant) going through the throttle body, since combustion chamber temperature is directly proportional to the amount of nitrous oxide formed during the combustion cycle (ergo, injecting spent exhaust gas into the incoming air charge to provide an inert gas that cannot ignite, reducing combustion chamber temps).
A quick Google search (Exhaust Heat Risers Debunked - Myth and Fact) shows that exhaust heat risers were designed to do the same thing as the throttle body coolant line (well, relatively) - to reduce or eliminate carburetor icing during high-humidity, low-temperature weather.
Either way, it's a bullshit system that doesn't actually do anything, other than adding some rubber lines to the engine bay. But, if CA had their way, we'd all be riding Mr. Garrison Wheels and farting butterflies.
#35
I have an LS6 manifold on mine and removed the EGR and AIR. when inspection time came I took it to a Ford dealer that I know and it passed, they didn't even know it was supposed to have those things. I'm in Mo. though. but they still do the sniff test and did look for cats.
#37
1 Post
take your throttle body off, remove the lower in/out for the coolant, grind down the nub on the t/b left by removing the in/out, replace your coolant hoses (expecting you did the t/b bypass like most w/a small pipe and hose clamps) with a single hose and go to another station...
