ls1 Question
i would do a bigger cam as well, thats a lot of work for a little tiny cam. do at least something in the .580's for lift. but yes you are on the right track. ls6 intake and heads plus a nice street cam will get you a very stout street beater.
Any suggestions?
Well its not gona be a daily driver until maybe next year ( Have another car ).
What gears do you have?
I have stock gears
etc etc. the 228r will actually produce very similar numbers it will just respond better to bigger heads, ie AFR 205's or maybe even milled 210's. but again these two cams were design for the street, they have a killer mid range torque band, and you can keep the cam and still take your set up to pretty crazy numbers.
