Installing headers and I had a question
Old Mar 26, 2010 | 11:48 PM
AR15 guy's Avatar
Default Installing headers and I had a question
I just recently picked up some never installed pacesetter headers with a ORY, but I am missing some hardware. My LT1 pacesetters came with new bolts and all that jazz....
I did not get that stuff this time around. I know everyone recommends using the stock manifold gaskets so I will do that, but can I reuse the stock manifold bolts? I assume not, but someone told me I could...
What say you ls1tech? If I need to buy new ones anyone have any recommendations?
Old Mar 27, 2010 | 12:11 AM
7th Darkness's Avatar
The stock ones will work, but if you dont want to reuse them I know the Auto Parts by me have header bolts u can buy.
Old Mar 27, 2010 | 12:23 AM
Mumbles's Avatar
Every header install I've been a part of, we reused the factory manifold bolts. No trouble with leaks or anything like that.
I'd recommend reusing them.
Old Mar 27, 2010 | 01:09 AM
sjsingle1's Avatar
stock bolts are fine.....have stage 8 bolts but ended up not using them
Old Mar 27, 2010 | 01:21 AM
blue98Z's Avatar
I used the stockers on two installs and no problems at all. I would check your stock gaskets before reinstalling them. The last set I did the stock gaskets fell apart so we used the ones that came with the headers. No leaks with them either.
