ASP underdrive pulley kit
check it out and let me know what u guys think... also let me know if thats everything i need there or do i need something else for the install http://www.lgmotorsports.com/OCLS1_Fbody_Engine.htm
As for the amp and sub ? I think that if you go with the complete kit you should be fine. The only time you may worry is if you go with the crank pulley only. The friend I mentioned had to get the alt. pulley because he had a prob with the volts being low before.
I know I'll get the pullies soon!
