New SS Induction is complete. Video inside..
Anyway I grabbed my DV camera and shot a quick video to give you the basic over all view of the finished product.
To fill you in I made a system for grabbing air through those holes in the nose of the Camaro. I used 4" aluminum tubing and sheet metal, I wrapped all the tunbing with silver heat relfective tape to seal amy leaks and keep heat out. I put fiberglass mesh screen at each side of the induction inlets down low. The screen is about the same stuff you would find on your screen for your back porch or pool. Its hard to see in the video. Anyway I am still running my MAF screen so having 2 layers of screens should be sufficient to keep out large debris.
Here's the video: New Induction for the SS
If all things work out well I am going to take this design and have the tubing remade with 4" mandrel bent aluminum or I am also thinking about using some 4" tubing and making a fiberglass intake.
This new ram air setup should work well when I install an LSX intake with a 90mm throttle body in the near future.
I'm racing this upcoming weekend and will post results.
Lee
Other then that, the system/car looks great, and I hope it works out good for you. Definately a creative idea and excellent execution.
You could easily figure out a way to throw a square filter on that. Even if it was half assed, it would still probably do the trick.Rob
If this car is to be driven on the street, there's alot of **** out there, from rocks to bolts, **** gets fling up in the car in front of you and hits your front fasica, how about a bird stuck in my foglight opening which happened 2 summers ago.
My car is a track only car, 100% race car never driven on the streets. In fact I will have the title to my 02 SS by the end of the month. I plan to cancel my full coverage insurance and registration. I had to have full coverage since I had a loan on the car but the last payment is going out this week.
This new induction is something I've been wanting to try for a while, since I had time off over the holidays I went ahead and built it. I do ALOT of bracket racing and some heads up racing once in a while. I still have my FIPK and will be bringing it with me to the track to test runs with both setups. If things work well for the dual/scoop setup I will keep it for heads up style racing like Thunder Shootout and LS1tech Drag Series.
I've talked with several racers that have claimed to pick ET by making a scoop for air. They have said that removing the ait filer doesn't do anything, but making a scoop with no air filter showed a reward.
I'm not holding my breath that this will gain me a whole tenth. Ya gotta experiment sometimes, blaze your own trail and see what happens =)
Lee
looks sweet, hope you find some gains in it.
looks like you race anything with wheels that you can down the track, very cool!
and i am pretty darn sure that is a track only car.
