Egr and air tubes block offs.
Old Jan 4, 2004 | 06:15 PM
TWISTA TA's Avatar
WARNING: BAD TRADER STATUS
Default Egr and air tubes block offs.
If I block of my egr and air tubes on my 2000 ws6 and then install a ls6 intake will I need to do any computer tuning?
Old Jan 4, 2004 | 06:49 PM
ss rally red's Avatar
You will have to edit out the egr code that will show up the first time you drive it. In most cases the AIR usually wont set a SES light,but might as well go ahead and delete it also. You wont have to do any other "tuning" per say from just adding the intake.
Old Jan 4, 2004 | 07:45 PM
Jeffs99SS's Avatar
I read a while back that vehicles with egr run a different tune than those without egr. Is this false? I was always under the assumption that the car would run the same w/out egr, but would set a SES light if it wasn't deleted. I am interested in this as well, because I would like to get rid of egr when I intall an ls6 intake.
On a side note, I am in California. Since 01-02 cars never came with egr, would it be right to assume that removing it on a pre-01 car would not cause any problems passing the sniffer (provided the code is deleted). Or is there something else on 01-02 that replaces the egr?
Jeff
Old Jan 4, 2004 | 07:48 PM
onehardmaro's Avatar
A calmer cam i think.
Old Jan 4, 2004 | 08:26 PM
The cam profile has a milder grind in the 01-02's. I believe it is closer to the 5.3l truck grind.
