***4" mufflex finally installed!!!***
here's the result of a couple pushed up valve seals. smokin like a damn chimney.
http://www.youtube.com/watch?v=vT7xBllQMe4
only blows a tiny bit of smoke now, but thats normal. i'll try to get some more vids up soon.
edit: still need to get around to painting the muffler.
I'm with you when you say you need to paint the muffler. The giant box under the car isn't all that attractive. But, like you stated earlier in the thread, its not like you have your head stuck under the car all the time. A little disguise in the form of some high temp paint wouldn't hurt though.
Like I said, car sounds great. Good choice of setup.
799 heads
ls6 intake
prof products 85mm tb
30lb SVO injectors
TSP 224r cam(224/224, .581/.581) 114lsa
comp magnum 5/16 x 7.400 pushrods
patriot gold dual valve springs
mufflex 4" cat back with 3.5" stainless tails
TSP o/r y-pipe with flowmaster 4" merge
pacesetter ceramic coated LT's
slp lid, holley power shot filter
hurst billet pro shifter
melling high volume oil pump
n-motion LS2 single roller timing set
.) Any idea why? We have nearly identical mods except for the c/b, TB and heads. I'm on an LS6 top end with a 78mm TB and TSP Rumbler CB, 224/228 cam and running 414/372 RW on a lean tune. I KNOW it can push more, just don't have the PAY to PLAY right now.What are the 799 heads? I'm a bit outdated on my RPO's and casting #'s right now.
