Large mufflers with true duals and ground clearance?
Using Offset/Center mufflers seems like the best way to keep the most ground clearance. I looked up the dimensions on your mufflers and they are only 4.5" thick while the Max Flows I want are 4.75"
I'm going to put my car on the ramp tomorrow though and measure the amount of room I have to work with. The clearance looks fine on your car for true duals with real mufflers. I agree, the offset/center combination seems to work the best for this setup. Sorry about the wrong info on the size there. You can see the mufflers hanging down a bit if you are behind the car. My car is far from what I would call quiet with them, but they were a huge improvment over the bullets.
They are larger than the mufflers Jorday posted in every direction and ground clearance would be a serious 2". Jorday's mufflers are just skinny enough to tuck up into the floor boards where there's a little room. The width of the Maxflows won't allow that and they're already another 1/4" thicker than Jorday's mufflers so you lose twice as much ground clearance. I've decided to go with the 1 chamber flowmasters since they are very small and can be tucked up for a lot of ground clearance. btw...even though they are not shown in my pics, turndowns will make a noticeable difference in the level of interior noise.
