Ignition Wiring Error
Old Apr 8, 2010 | 03:06 AM
JimmyJazz's Avatar
Default Ignition Wiring Error
I am hoping someone can help.
I have a 2002 LS1 that I am using in a project car. I am using the exsisting wiring loom and ECU. In my ignorance and stupidity while thinning the loom out of unwanted wiring I now have no 12v supply to the Coil Pack Subharness Connector Pin H, Pink Wire. and subsequently no spark
The wire leaves this plug and teminates at a common connector nearby.
Where does this wire continue too. Does it go to a pin on the ecu or is it a switched live on the ignition or maybe something else.
I hope I have explained myself well enough. Please ask if you need more info
Thanks Alan
Old Apr 9, 2010 | 03:24 AM
JimmyJazz's Avatar
Anybody out there got any ideas. I could really do with a helping hand
Old Apr 9, 2010 | 04:08 AM
joecar's Avatar
Does this diagram help...?
Attached Thumbnails Ignition Wiring Error-700007.gif   Ignition Wiring Error-700012.gif
Old Apr 9, 2010 | 04:22 AM
LS1MCSS's Avatar
The same wire that powers your coils also will power the injectors. One pink wire will power the even numbers and another will power the odd numbers. If you have power at the pink wire to the injectors, you can tap into those wires for the coils.
Old Apr 9, 2010 | 05:02 AM
JimmyJazz's Avatar
Many thanks for the replies. Unfortunetly all the pink wires, including the injectors terminate together on each side near each coil pack multi connector. I have obviously foolishly stripped out the feed wires that come from somewhere like the ecu or ignition, just not sure where this feed comes from.
Alan
Old Apr 12, 2010 | 01:07 PM
Pocket's Avatar
Check the pinout for your pass fender connectors. The INJ fuse wires run directly to the fuseblock
Old Apr 12, 2010 | 08:38 PM
joecar's Avatar
Will these diagrams help:
Attached Thumbnails Ignition Wiring Error-batt.gif   Ignition Wiring Error-.gif   Ignition Wiring Error-d.gif   Ignition Wiring Error-k.gif   Ignition Wiring Error-n.gif
Old Apr 12, 2010 | 08:40 PM
joecar's Avatar
And this one:
 Michael S. Palmer
Old Apr 12, 2010 | 08:45 PM
orrious's Avatar
The pink wires should only be hot in run and start. Each side should have a separate 15amp fuse. Do NOT tie both even and odds together. Depending on the vehicle your swapping into, you might consider using a relay between fuses and battery, unless your tapping directly into one of the RUN/START primary's directly from the key.
Send me a PM if you like and I can pull the wire diagrams from both vehicles and create a cross reference for you.
