Rear-end
Old Apr 8, 2010 | 06:37 PM
tazer21690's Avatar
Default Rear-end
So I had my rear-end rebuilt after I had a pinion seal leak. This was about January time-frame. It's now April and I had to put the Camaro back in the shop due to new problems in the rear. I kept getting a popping sound when pulling forward or reverse with the steering wheel to the left. A buddy says I need c-clip eliminators but I dunno what it is. What do you think it might be and what do you recommend to do? If it's parts, what name brand do you recommend? I have a 99 Camaro SS with 3.73 gears in the stock differential (i believe it's a 7.5 or 7.625in). I need help, please
Old Apr 8, 2010 | 07:34 PM
ROCNDAV's Avatar
Could it be your U-joint?
Old Apr 8, 2010 | 10:09 PM
massls1guy's Avatar
your question would do better over here:
https://ls1tech.com/forums/gears-axles-15/
