help removing ac
Old Apr 10, 2010 | 06:40 AM
ls1curt's Avatar
Default help removing ac
hey, i just started to pull out my ac. i got the condensor and all the lines out. all i got left is the thing that is attached to the firewall. does anyone know how i can get this out without wrecking it? are there bolts on the inside and outide of the firewall? and do i pull it out through the dash side or the engine side?
thanks
Old Apr 10, 2010 | 09:34 AM
wowsers's Avatar
pretty sure you have to remove the dash to get the heater core and everything out. youre gonna need a plate to seal the big hole in the firewall too. i havent done it but thats what it looks like to me.
Old Apr 11, 2010 | 01:33 PM
ls1curt's Avatar
im planning on leaving the heat in. yeah i saw some pics of the hole and it would be pretty easy to make a plate, i just want to be able to put the ac back in if i ever decide to
Old Apr 11, 2010 | 02:03 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
https://ls1tech.com/forums/drag-raci...-question.html
