why would they use 2.5" pipe from LT headers
I'd be really interested in seeing just how much power you give up in the 4k plus area with a 2.5" setup, on a car with over 500fwhp.
I can only imagine that the city-driving-torque would be better on the 2.5" setup... but how much less would it pull up top on a car that "exceeds" the 2.5" threshold?
In other words, how different would a 450rwhp car feel (or trap) with a full 3" vs a 2.5" setup. I see half an inch of ground clearance being worth the a few ponies, but not a tenth of a second...
you need the backpreasure.
even the ricers haven't
figured this out those giant coffee cans reduce the backpreasure.
I would be more concerned w/ what or how they made the Y was it madel bent? did they flange it for removal slip on's w/ band clamps don't seal that great. post images.
here's a image of mine 3" reducers into 2.5" Y Mandel bent into flowmaster merge out to Hooker cat back.flanged front and rear
BTW a Y will sound a bit raspei.
good luck.
If I was op I would just keep the 2.5. Imo I dont think it would be worth the extra money for the extra gain if any.
there's only a difference of about 5-6 rwhp between a 2.5" y-pipe header system from Dynatech and a 3" header system from American racing. So i guess unless you're looking
for every single HP then it's not a big deal. I had FLP headers for years and ran good times for the small heads/cam setup that i had. Plus there were alot of fast cars that ran MAC headers. Alot were in the 10's. But if i installed a 427cid in my '02 SS then i probably would opt for the larger header/y-pipe setup.
Back in the day there were debates about the y-pipe size, but there were a lot of cars
with MAC headers and FLP's that ran in the 10's. I wouldn't have a problem buying a set of Dynatechs with their 2.5" y-pipe and 3" merge. Unless I was going with a 427cid then i would definately want a larger y-pipe.
