why would they use 2.5" pipe from LT headers
Old Apr 10, 2010 | 01:34 PM
CrazyDrivinJoe's Avatar
Default why would they use 2.5" pipe from LT headers
So I installed some pretty sweet headers last week but the company didnt have a y pipe for it until now. So I went and had a custom exhaust shop finish it off and they used 2 and a half in piping and its raspy and not loud at allll So im pissed. I am thinking of getting the y pipe and getting a flowmaster merge and go back and tell them to put that instead. The question is am I wasting my time by spending all this money or is it worth it for power and sound?
Old Apr 10, 2010 | 04:09 PM
zracer323's Avatar
What is the collector size on your headers? If it is 2.5" then a 3" y-pipe isn't going to do much for you.
Old Apr 10, 2010 | 04:24 PM
Pharcyde50's Avatar
Dynatech suppermax headers come with a 2.5" y shouldn't be too much of a restriction unless you pushing over 400hp.
Old Apr 10, 2010 | 05:20 PM
Mike@ZMS's Avatar
If you really think about it, a single 3" pipe will support upwards of 500hp. Dual 2.5" pipes wont hinder most setups unless your making crazy power.
Old Apr 11, 2010 | 08:42 AM
I just dont understand y an exhaust shop would use 2.5 inch pipes when the header collectors are already 3 inches its just stupid that they would do that and restrict me.
Old Apr 11, 2010 | 08:46 AM
01ssreda4's Avatar
because your average everyday exhaust shop is not performance oriented.
Old Apr 11, 2010 | 09:12 AM
yea I am pissed and wish I just would have waited and not wasted my time there so I just bought the Y pipe and I am gonna tell them I want them to install it at no cost.
Old Apr 11, 2010 | 09:13 AM
02 BLK WS6's Avatar
They used 2 1/2'' because you didn't tell the to use 3''. THey're not the only party to blame here.
Old Apr 11, 2010 | 09:14 AM
KurtRardin's Avatar
Veteran: Marine Corps
+1
...and they will look at you like you've got an arm coming out of your forehead if you even speak about 3" pipe. They've got so many "backpressure" stories under their belt and most of them assume that your car has a 350. 2.5" exhaust has been about the standard size for muscle cars over the years, and unless they've been around LS performance stuff then it's pretty safe for them to assume that you just want them to do what they've been doing to muscle cars for years.
2.5" wont kill your power too bad. You'll have good ground clearance...
Old Apr 11, 2010 | 09:26 AM
Gordo78's Avatar
+1 if you just said "hey i need a Y" they're gong to do it their way.
Old Apr 11, 2010 | 09:29 AM
99345hp's Avatar
If you read a lot about exhaust pipe, having 3" pipe on a motor not needing 3" it will actually hurt flow. Backpressure isn't the only thing to think about.
If you have an exhaust pipe that is too large, it will decrease the amount of heat inside the exhaust pipe. Decreasing the heat inside the exhaust will decrease the velocity. If you have 2 pipes, 2.5 inches is good for up to 500 bhp. 2 3" pipes is good for a motor creating around 700 bhp. Going too big will hurt flow, I have heard this many many times from engine builders.
A customer of ours has a program on his computer that will calculate power for a given engine combination and it is usually close ( within 5%). With that program you can change header primary size, length, and collector size. You can also change exhaust pipe size and length.
We were building an exhaust for an impala with a 502, 500 bhp. Changing the exhaust from 3" to 2.5" created no loss in power. The rasp your are experiencing is most likely in the design of the Y, not in the size of pipe.
Old Apr 11, 2010 | 12:40 PM
BlurSS's Avatar
My input is that for my loudmouth it is 3" in an 2 3/4 out. I could run 3" in and out but how would that help its still going down to 2 3/4 on the way out. In a true dual setup it would be worth 3" all the way back with 3" mufflers if I had the power to support it.
Old Apr 11, 2010 | 02:29 PM
RevGTO's Avatar
Pontiacerator
There's nothing wrong with using dual 3" into 2.5" reducers into a single 3" I-pipe with a good merge. You maintain good velocity and gradually reduce down. It's much better than most of the old style Y-pipes that slammed two 3" into one 3" and then reduced down to 2.75" at the I. That is your greatest point of restriction, not the dual 2.5" pipes going into the merge.
Old Apr 11, 2010 | 06:20 PM
Paul Bell's Avatar
That's MISTER MODERATOR
+1 with this^
Old Apr 11, 2010 | 06:28 PM
KurtRardin's Avatar
Man, does anyone have a dyno graph of the exact same car laying down numbers with a 2.5" system, and then once again with a 3" system?
I'd be really interested in seeing just how much power you give up in the 4k plus area with a 2.5" setup, on a car with over 500fwhp.
I can only imagine that the city-driving-torque would be better on the 2.5" setup... but how much less would it pull up top on a car that "exceeds" the 2.5" threshold?
In other words, how different would a 450rwhp car feel (or trap) with a full 3" vs a 2.5" setup. I see half an inch of ground clearance being worth the a few ponies, but not a tenth of a second...
Old Apr 11, 2010 | 06:33 PM
99345hp's Avatar
A tenth of a second? Really? How many people on here are worried about a tenth of a second? Let me reword that, how many people on here should be worried about a tenth? On a street car, a tenth of a second shouldn't really matter. That is a drivers error amount of time.
There is a point where 3" duals will help power, but if you have under 500 fwhp it isn't necessary.
Old Apr 12, 2010 | 07:19 AM
I guess there is no turning back now that I bought a y pipe from the people who make my headers. I will probably run this 2.5 inch setup until summer nationals when I am gonna cut it all out for the weekend and then install the better y pipe in.
Old Apr 12, 2010 | 08:22 AM
DaveX's Avatar
You should have specified 3" pipe if that is what you wanted. I don't really see where the exhaust shop is to blame here.
Old Apr 12, 2010 | 11:05 AM
01ssreda4's Avatar
Who cares at what point you "need" the 3 inch. Maybe OP wanted it. I wouldnt run dual 2 1/2 pipes ever, no matter how many times someone like you tried to convince me it was ok.
Old Apr 12, 2010 | 04:01 PM
TImmy_Jones's Avatar
How does the merge on the pipes look? I would be more concerned with that, then the diameter.
