Battery relocation help!!!
Old Apr 12, 2010 | 11:56 AM
2002RamAir's Avatar
Default Battery relocation help!!!
Im relocating the battery to the spare tire well. I have everything almost wired except the battery terminals. I have a 1/0 wire running to batt from alt. I have a second 1/0 wire running to the starter then a 4ga going from starter to the factory fuse panel. My question is should I run a circuit breaker in the line from the alt to batt? If so what amp? 150? 200? The alt is the factory alt with no extra current draw... Thanks
Old Apr 12, 2010 | 07:45 PM
99345hp's Avatar
The circuit breaker is going to have to be higher in rating than what the starter pulls during a cold start. On every car I have ever wired from scratch or seen wired from scratch I have never used or seen a circuit breaker inline before the starter or alternator.
Why did you go to the alternator from the battery first? I would go battery to starter, starter to alternator, then alt to fuse panel.
Old Apr 12, 2010 | 08:24 PM
bayer-z28's Avatar
Engines typically pull around 1 amp per cube.. So figure a 350a fuse, tops.
My buddy did the conversion a while ago and we ended up rigging up a breaker inline between the new cable and the stock batt line and chopped the connector off. His Taylor kit was JUST BARELY long enough.
Old Apr 13, 2010 | 01:39 PM
2002RamAir's Avatar
Sorry for the confusion... I actually have a 1/0 ran from batt to alt then a seperate 1/0 ran from batt to starter then starter to fuses...
Would I want a breaker between the batt/alt line?
Old Apr 14, 2010 | 09:34 PM
99345hp's Avatar
I dont think you would need one there, it would only protect if you had a dead short in the line somewhere in the circuit.
Old Apr 17, 2010 | 08:02 PM
tom falco's Avatar
1/0 wire are you supplying the entire state of kansas with power?????? All you need is a 1 GAUGE wire and a #6 to the alt. I never use any wire thicker than 1 gauge on any conversion i have done.
This setup uses a 1 gauge wire to the engine with no problem whatsoever. Using a 1/0 cable is totally not necessary.
http://i600.photobucket.com/albums/t...Picture007.jpg
Old Apr 18, 2010 | 09:35 PM
BrianC98Z28's Avatar
why do you redo all the wiring when you dont have to? Kind of at a loss at people that do extra work not needed at all.
Old Apr 20, 2010 | 05:59 PM
tom falco's Avatar
Because its in the way and cleans up the engine compartment. Not to mention i needed the space for my TURBO LINES
