PS cooler for my camaro ss
you can do that, or just get a line for the Z28's along with the upper radiator hose for the same car...then just bleed the PS system. as long as you do this when the car is stone cold, you wont have to bleed the cooling system as there wont be any fluid in the upper hose.
Are the "TURN ONE" power steering pumps any better than the stock ones?
Also, I would like to see more coolers that everyone is using and putting on.
I've still got the stocker, and as far as I know, it hasn't started leaking or anything. However I have had problems with my power steering. Had to replace two pumps, and my rack is now leaking
^ The turn one PS Pumps have a better ratio, IIRC. The stock PS pump is fine for the average joe daily driving his F-Body, but when you ask any kind of performance, or twisties from it, it cooks itself... Once you start doing some constant turning at higher RPM's the fluid boils and it WILL boil. Just ask me how I know. I've been through this ordeal MANY times, to include boiling fresh full synthetic oil.
The T1 pump won't cook itself. If someone could just elaborate on what exactly the difference is.
The aftermarket cooler is placed in line returning to the reservoir. Between the reservoir and the rack, IIRC.
I'm pretty sure the turn one pump flows 40% less fluid than stock. The stock pump flows so much in order to achieve a very light and consistent steering feel all the way from idle to redline. The turn one will be a little harder to turn at low rpm, but at high rpm autox type driving, your coolant isn't going to get as hot, If i understand correctly. If you can't tell, I'm having some steering issues myself... I was considering the turn one pump, but can't justify the cash right now. I'm working on getting the car to the point where it will handle good enough to boil PS fluid first. I did, however, pick up a billet 8 spoke wheel from Mike at Wazee's Pulleys. Great guy to deal with, he helped me out and overnighted the thing to me on a Friday afternoon. Awesome quality, fit, finish on the pulley. I am a machinist by trade so you know my eyes ain't crooked.
if not all cars came with it, does anyone know the part # for the factory return line used in a non-cooled application? i am trying to avoid paying 110$ for a return line, i figure i will take the cooler out and run a stock return line...
