LS6/Weiland intake
Old Apr 21, 2010 | 07:48 PM
ChrisBorsheim's Avatar
Default LS6/Weiland intake
Looking at these two options,
anyone have an opinion on which is better preferred low/mid range improvements.
Old Apr 24, 2010 | 02:08 AM
still nothing?
Old Apr 24, 2010 | 06:45 AM
AFASTYZFR1's Avatar
LS6 or Fast
Old Apr 24, 2010 | 07:18 AM
RPE_2KTRANS's Avatar
I just installed on the aluminum,have not run it yet.My pcm is sending out to 1BAD_LS1.
I will post when I get back.
Old Apr 24, 2010 | 07:28 AM
BOTTLE ROCKET's Avatar
The Weiland has not had a lot of followers because of it's aluminum construction is susceptible to heat soak. Haven't seen a lot of numbers, and if it beat the Z06, I'm sure someone would have posted them by now.
The Z06 is a pretty good mid/high rpm intake, is light weight, and does not have ANY heat soak issues.
If you're interested, I have access to a Z06 intake that I just pulled off of a neighbors 2004.
Old Apr 24, 2010 | 03:32 PM
99Bluz28's Avatar
The problem with the Weiand intake is it won't really benefit from a larger then stock TB, unless you or a shop enlarges the TB opening. And it uses it own/different intake seal/gaskets. That's why I went with the BBk (85mmTB opening & uses factory seals) instead of the Weiand.
IMO, if your determined to get the Weiand intake at least get the TB opening opened up to 90mm.
Old Apr 24, 2010 | 04:51 PM
DCC!!'s Avatar
^^ how do you like the bbk i was lookin at that then backed down...
Old Apr 24, 2010 | 05:59 PM
99Bluz28's Avatar
I have no complaints with my BBK SSI & 85mm TB, it seems to pull stronger above 3,500 rpm then my LS6 and ported GM TB did.
