car shut off. TB maybe?
Old Jan 7, 2004 | 09:45 PM
LS1Paula's Avatar
Default car shut off. TB maybe?
My boyfriends car died tonight when he was backing out of a parking lot and he gave it a little gas and the rpm's sank down low....... too low and then the car shut off. Would cleaning the throttle body with a Q tip and some alchohol solve the problem?? If not, what would? thanx alot.
-Paula
Old Jan 8, 2004 | 11:02 AM
CamaroCain's Avatar
what car is it, and does he have any mods done?
Old Jan 8, 2004 | 11:40 AM
2002 Trans Am's Avatar
Did his car start back up, or is it dead?
Old Jan 8, 2004 | 11:47 AM
Texfinn's Avatar
Could use a bit more info... Make? Model? Mods? Is it totally dead? Does it crank?
I doubt, though, that just a dirty TB, like you are suggesting, would cause a car to just stall...
TS
Old Jan 8, 2004 | 03:02 PM
LS1 Brent's Avatar
it's my car. mods in the sig.
Old Jan 8, 2004 | 04:36 PM
Krab's Avatar
Have you checked the air filter for anything blocking air from getting in. Maybe you have some leaves or a plastic bag stuck under there.
Old Jan 8, 2004 | 04:38 PM
Can you describe a little more of what happened and whether you can start your car back up?
Old Jan 8, 2004 | 10:23 PM
LS1 Brent's Avatar
I backed out of the parking lot and let off the gas to push in the brake and put it in drive. When i did this, the rpm's sank too low and the car died. I threw it in park and started the car up just fine. I'm pretty sure I just need to clean my throttle body? Any tips on what exactly to do and what all you need to take off to get to the throttle body? thanx alot.
Old Jan 8, 2004 | 10:57 PM
CLB3RD's Avatar
This happened to me before in my ls1 a4....what happened was you put it into drive to fast while your car was still rolling backwards. I did it when i was pissed off and back out of my driveway real quick then started decelerating and threw it in drive to quick. Car died, then started right back up.
Old Jan 9, 2004 | 12:00 AM
It has happened to me before in my Explorer. Nothing ever came of it and I never did anything about it. Explorer is fine now and that was like 3 or 4 years ago. Don't worry about it your fine
