Prothane motor/tranny mounts.... need advice
Old May 9, 2010 | 01:37 PM
brandon_01_ta's Avatar
Default Prothane motor/tranny mounts.... need advice
after my lt's and Y-pipe install i've had a real problem with the drivers side fitment... the header is resting against the k-member in two different places... i had my mechanic look at it and he suggest to try poly motor mounts/tranny mounts... since i'm gonna do that i'm gonna go ahead and do a new torque arm bushing too.... so my question is which ones do u guys suggest and where's a good place to buy them... i saw on ws6store website u can get Prothane motor/tranny mount set for about $100.... good deal?
Old May 9, 2010 | 01:40 PM
maxspeed05V's Avatar
polly motor mounts are great, but if you decide to get the trans mount to expect alot of extra vibration.
I ended up putting the stock one back on .
Old May 9, 2010 | 01:58 PM
i was afraid of that... i won't mind a little vibration but if it's that bad i may not do the tranny mount... what exactly are the advantages anyway?
and will changing to a poly tranny mount even help with the header fitment at all?
Old May 9, 2010 | 02:22 PM
Black02SLPSS's Avatar
No the tranny mount doesnt do anything for header fitment. Thats more of the motor mounts job. But i had all of them at one point and i will say that nothing moved very much, but the trans mount made it a whole lot louder inside the car.
Old May 9, 2010 | 05:30 PM
conor.davis's Avatar
How bad is it hitting? You can notch a small amount of the K member and be fine if it still hits after poly mounts.
I got my mounts from WS6store too its a good price.
Old May 9, 2010 | 06:37 PM
the vibration is terrible and at times u can hear the header hitting and rubbing the k member... i dont know if the pass side is hitting at any time but it's clearing the k member by a quarter inch or more.... the drivers side is resting against the k member in two places at all times.... hopefully the motor mounts will help, if its still hitting i will have to dent or grind the k member a little.... i'm still just on the fence about the tranny mount cause the guy workin on my car suggested if i get poly mm i need to go ahead and do a tranny mount... which is fine but if it's as loud inside the car as u guys say it is then idk i might hold off on that... BUT, it is just a weekend car so it wouldnt be that big of a deal i guess.
Old May 9, 2010 | 08:05 PM
I would go for it and keep the stock tranny mount if its in good shape.
If you don't like it then throw the stock one back in.
Old May 9, 2010 | 10:51 PM
yep thats what i've decided to do... i just now ordered everything
should i see any kind of noticeable differences with a polyurethane torque arm bushing?
Old May 10, 2010 | 09:15 AM
TRANS-DAD's Avatar
Poly torque arm bushing & rubber trans mount here w/no prob.....didn't notice any dif.!
Old May 10, 2010 | 12:44 PM
blackfang's Avatar
I installed a poly trans one and holy **** did it rattle and vibrate I got a OE one from work the next day and put it in.
Old May 10, 2010 | 06:40 PM
crap... i have a feeling i'm gonna regret getting the poly trans mount lol
but, i've already ordered it so oh well....
