28lb injectors to 26lb injectors will I be ok?
Old 05-14-2010, 09:34 PM
DavidGXP's Avatar
Default 28lb injectors to 26lb injectors will I be ok?
Will this require retuning immediately, or will I be OK for the time being. Swapping form LS4 intake to LS1. I have all parts ready to go and should put down about 300hp
Old 05-14-2010, 10:45 PM
SOMbitch's Avatar
26#'s are perfectly adequate for that power but they are a direct swap so why not run the the 28's????? Is the car already tuned for the 26's??????
Old 05-14-2010, 11:35 PM
DavidGXP's Avatar
LS4 5.3's come with 28lb EV2 injctors stock. I bought some used LS1 injectors, thinking that they were all 28lb only to find out later that they were 26lb. I have a LS6 fuel rail and pig tail adapters. I will switch to 28lb injectors later. I just want to run what I have. I would use my stock injectors but they are to short and the LS4 fuel rail don't fit the LS1 intake.
Old 05-15-2010, 03:01 PM
djfury05's Avatar
do you know what year Fbody the LS1 injectors came from? 26s will still be fine though you won't notice a difference. The only drawback is that the 26s will maybe be running 5% harder
Old 05-15-2010, 11:53 PM
DavidGXP's Avatar
Came off a 2000 LS1 Camaro
Quick Reply: 28lb injectors to 26lb injectors will I be ok?
