LQ9 Swap with Power steering delete??
Old May 18, 2010 | 01:58 AM
02_ramair_ta's Avatar
Default LQ9 Swap with Power steering delete??
I have swapped in my 6.0, and drilled the hole for the Alt bracket, my question is, without powersteering how do you need to route the belt, and what size?? Ive read alot about 51.5 belts on an LS1 without Powersteering, but I want to be sure, alot of people mention removing one of the Alt bracket bolts to make that work, and I believe they are refering to the one I had to drill/tap to make the bracket work with the iron block!!!
Someone clear this up..
Thanks.
Old May 18, 2010 | 02:54 AM
jmsklmn's Avatar
I don't know if this helps but this is the setup I am running on my F-Body accessories.
https://ls1tech.com/forums/conversio...lt-number.html
Old May 18, 2010 | 09:35 AM
Yes, that helps alot!! I think I can get away with it the way I had planned.. Thanks again for the reply, you mentioned the belt coming off, has that happened since??
Old May 18, 2010 | 02:53 PM
jmsklmn's Avatar
I personally have not driven the car with this setup yet but if you are worried about the belt slipping off, scroll down a little bit and you will see another setup with an additional tensioner. Seems like either will work! Goodluck!
Old May 18, 2010 | 09:40 PM
I noticed that, thanks, I am going to try your way, I will post the results.. seemed like a good deal, when I hooked it up..
thanks again.
