TB size matchup to the LS6IM
Old Jan 11, 2004 | 09:47 PM
SLP LS1's Avatar
Default TB size matchup to the LS6IM
How large can you go with the TB to match the LS6 intake manifold size. I know our TBs are 75mm stock. I'm wondering what is the size of the LS6 manifold? I want to make sure I have a good matchup!!! I might go with the BBK 80mm, but I don't know if it is worth it; If the LS6 IM matches the size of the BBK TB. I'll probably end up just getting bauer's ported tb! I would just like to know the info.
Old Jan 12, 2004 | 08:48 AM
Old SStroker's Avatar
LS1 & LS6 intake is about 75.5 mm. Just big enough to keep from having a step when the stock size TB is installed. There's almost no room to enlarge it. A larger TB needs a step-down adapter.
