View Poll Results: What did you have to do to fit your longtubes in?
Nothing! Fit like a glove!
36
40.91%
Unbolted Steering Knuckle
24
27.27%
Unbolted Motor Mount
7
7.95%
Removed Oil Filter
17
19.32%
Purposely dented headers in
1
1.14%
Purposely dented K-Member
6
6.82%
Grinded the engine block a bit
12
13.64%
Forced it in and accidentally scraped/dented headers (still works fine)
4
4.55%
Other
12
13.64%
Multiple Choice Poll. Voters: 88. You may not vote on this poll
How did you install longtube headers?
Old May 20, 2010 | 10:52 AM
cyberkill's Avatar
Default How did you install longtube headers?
Just finished my poly MMs (and tightened them) and having some trouble with my Pacesetter LTs on the driver's side. I've been reading a ton of old threads and it seems like there are so many different variations on how people have gotten them in. Just wanted to see what the most common thing people do to get longtubes in in a nice little poll.
Check all that apply!
Old May 20, 2010 | 10:58 AM
98TAjwh's Avatar
i unbolted the motor mount and the steering knuckle. went right in after that.
Old May 20, 2010 | 11:05 AM
Red Devil 99''s Avatar
i was changing the oil at the same time we did the install, both went right in pretty easy as long as you have the car up high enough.
Old May 20, 2010 | 11:15 AM
Bad Notch's Avatar
I pre-ground my K member before even test fitting my headers. They fit right in like a glove.
Old May 20, 2010 | 11:16 AM
fast377's Avatar
All the ones I've done, have gone in (from the bottom of course) no problem. Never had to mess with motor mounts or steering shaft.
Old May 20, 2010 | 11:25 AM
cyberkill's Avatar
PLEEEEASE teach me! I'm very reluctant to grind or bend or dent anything.
Old May 20, 2010 | 11:29 AM
blackfbird98's Avatar
i just did my pacsetters this past weekend and it was stupid easy i didnt have to take anything off i just had to **** the headers and tilt them, once they were in the right angle i pushed them up and in place.
sjsingle1's Avatar
removed MM pedestal.....steering link......oil filter......on drivers side.........pass side........fit like butta
Old May 20, 2010 | 12:01 PM
fast377's Avatar
I'm sure it's a little different from brand to brand, but mostly, I think it's just a matter of getting the car up high enough to snake them in. Once the stock exhaust is out of the way, it's never taken me more than just a few minutes to slide them up and put a bolt in.
Old May 20, 2010 | 12:28 PM
robsls1's Avatar
SLP headers drivers side went in no issues after loosening the steering knuckle. The passenger side took 2 small bangs on the firewall to get it in.
Old May 20, 2010 | 12:40 PM
Justus67's Avatar
I did mine on a motor swap, so I guess I cheated.
Old May 20, 2010 | 12:41 PM
Justus67's Avatar
And that was on ebay specials.
Old May 20, 2010 | 04:32 PM
Trevor.j's Avatar
+1 for ebay !!
Old May 20, 2010 | 04:34 PM
TooLateVTEC's Avatar
I had to cut the tab off the block, remove oil filter, remove that thing that unbolts next to the filter, and unbolt the steering knuckle. Pass side was cake even with the plugs in haha.
Old May 20, 2010 | 07:04 PM
cyberkill's Avatar
Is this the steering knuckle everyone's talking about? I took the one out on the right side of the picture, but the thing doesn't really move anyway.
Old May 20, 2010 | 07:56 PM
fasteddie94's Avatar
That would be the one. Actually to do my cousin's ARHs we had to go to the end that comes out of the firewall. I took out the wire clip, slid the black sleve off and slid the white busing out of the mount on the firwall. It didn't actually diconnect the shaft but it did give us plenty of movement to get the header through there.
I didn't mess with the bolt in the joint for too long. at first I took out the bolt but found I didn't have enough room to slide the shaft apart without unbolting more stuff. I put the bolt back in and did as I described above.
I have also installed jet hots and hedmans with no issuse at all, just had to get the car high enough.
Old May 20, 2010 | 08:32 PM
candidate zero's Avatar
When I installed Pacesetters in my garage, I removed the steering shaft. When I installed Hookers on the lift at work, I didn't remove anything.
Old May 20, 2010 | 09:30 PM
cyberkill's Avatar
I don't remember if my TSP Y came with instructions or not, but I don't have them. I have 4 U Bolt Muffler clamps and 2 wide pipe clamps. Can someone tell me where each of the clamps go? I have the Y pipe put together, just need to clamp them.
Also, do you assemble the Y pipe and then put them on the loosely attached headers or do you assemble the Y pipe piece by piece under the car?
Old May 20, 2010 | 09:37 PM
JimMueller's Avatar
My Grotyohann's were done on jack stands back in 2001, and IIRC we had to take out the engine mount bolts on one side to get them in. When I switched to ARH's about 2 years ago on a lift, they would not fit with the aftermarket Torquemaster starter I had, but fit perfectly after installing a stock starter.
Old May 20, 2010 | 10:23 PM
garygnu's Avatar
also consider unbolting the trans mount,and jacking up the trans a little.
