Temp Guage Stuck at 180ish
Thanks.
See if it changes, if so, then its dead. if not it could be the guage
I have a auto meter one hooked up in my car and i can tell you that my cars temp jumps from 160 if driving in the freeway to 210 if stuck in traffic. The stock gauge does not move if your car is anywhere from 160 to 230 i beleive it is. It only moves up higher from that once your car reaches over 230 and by then your pretty much getting ready to overheat these aluminam blocks.
The computer does see the "real" temp, but the gauge is hooked to the computer via a serial port connection (as I understand it). The computer interprets the actual signal, then sends the dummy temp reading to the instrument cluster. Either live with it or put in a custom temperature gauge - like most folks do...
Those are pretty much your altenatives without spending big bucks....
