Spark Plug Issue!
Old May 28, 2010 | 10:29 PM
Badguy7's Avatar
Default Spark Plug Issue!
Ive got this problem with a plug, basically welded itself on to the block. Ive removed 7 out of the 8 plugs, all were pretty tough but this 1 just seems like its welded on there. I didnt want to keep on trying and end up breaking it, so i installed the other 7 new plugs and have ran it this way for the passed few days. So i wouldnt be without a car at the moment.
So my main question here is, how do i go about getting this plug removed without breaking the plug off? If there is a way.
Old May 28, 2010 | 10:33 PM
BLUES MAN's Avatar
The House is Rockin'
man, maybe try alittle wd-40
seriously i would get that plug out ASAP
Old May 29, 2010 | 03:17 AM
joecar's Avatar
Which cylinder #...?
Old May 29, 2010 | 11:39 AM
Badguy7's Avatar
Its #4.
Old May 29, 2010 | 08:51 PM
89 formula350's Avatar
when the eng is still nice and warmed up (not blazing hot!) spray pb blaster or if you can get it GM heat valve lube on the threads.. several times.. the heat and cooling help as well as the constant soaking helps draw in the lube
Old May 30, 2010 | 11:30 AM
Badguy7's Avatar
thanks, ill give that a try.
Old May 30, 2010 | 11:30 PM
"Grabby" 2000Z28's Avatar
Default Plugs
When you changed the plugs I hope you remembered to put anti-sieze on the threads of the new plugs .
It'll save you from this problem next time .
Old May 31, 2010 | 10:17 AM
Badguy7's Avatar
^ yea, the new plugs got anti-sieze.
