Is this suppose to happen?
This morning I finally got done fabbing up a pair of 3" x 11" magnaflow spun-cat metallic converters (part #59929) after my 1 7/8" headers into a 3" to 4" Y-pipe. After a quick drive around the block, both catalytic converters starting glowing bright red. After about 4 minutes of idling, they're still glowing bright red. My tune is dead on (without cats). I'm worried about driving the car around in this condition because of the thought of the cats melting, clogging up, then stalling my motor. Do I need to have the car retuned with the cats on to remedy the problem...or is this condition supposed to happen?
Any help would be appreciated.
It definitely has the cool factor. But it won't be so cool when my carpet catches on fire or something worse. I wouldn't be complaining as much if this was happening to my rear muffler at night.
You have coated headers or wrapped not letting heat disperse I dunno maybe shitty cats? No idea though lol. I would take those cats off or put some thick heat sheild by floor n such until you figure the problem out. Better safe than sry you know?
If your tune is good (as said check it, with a wideband), then maybe you have cylinder(s) misfiring and/or leaking injectors (i.e. some source of overfueling).
Do you have a scan tool that'll let you record long term fuel trim as you drive? It'll give you any idea if you are running rich.
