EGR block off plate
Old Jun 6, 2010 | 07:59 PM
99huggerorangeZ's Avatar
Default EGR block off plate
anyone have a EGR block off plate/gasket that deletes the EGR pipe @ the stock manifold??
Old Jun 6, 2010 | 08:10 PM
jdiddyws6's Avatar
Probably every vendor on here.
Old Jun 6, 2010 | 08:17 PM
Chubbz155's Avatar
Try speed Inc.! I got mine from there for a great price!
http://www.speedinc.com/catagory.cfm?catagory=Exhaust
Towards the bottom of the page.
Old Jun 6, 2010 | 08:36 PM
ok,do i just use the plate? i would think you would need a gasket,right?
Old Jun 6, 2010 | 08:59 PM
jdroelle001's Avatar
Just use some copper rtv on it, should seal up fine.
Old Jun 9, 2010 | 09:12 PM
Pocket's Avatar
Take the stock EGR/AIR tubes, cut the flanges off, weld the holes shut, grind flush. 30 mins to freebie blockoff plates
Old Jun 9, 2010 | 10:36 PM
patSS/00's Avatar
Use the original gaskets from the egr tubes, or if they're trashed you can get them from a dealer for a few bucks.
Old Jun 9, 2010 | 10:43 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I have always made my own. Pretty fast job if you have some spare plate laying around and a drill press.
Old Jun 10, 2010 | 10:47 AM
01ssreda4's Avatar
copper rtv is for high temp stuff, which would be good for the exhaust manifold. I have had bad luck with it on non-high heat applications. I never have bad luck with Ultra Black. I would use it for the intake manifold block off if you are just deleting the emissions.
