FAST Intakes @ Thunder Racing...THEY'RE HERE!
Old Jan 16, 2004 | 04:37 PM
  #221
Scalpel's Avatar
8POTS, any other info on that HSV GST300, where can I read about it?
Old Jan 16, 2004 | 05:50 PM
  #222
Got Me SOM's Avatar
Just fyi. Here's an email I got directly from FAST:
Jeff,
On a stock LS1, we saw about a 20 hp. increase. We saw about 15 hp over the
LS6 manifold. The manifold is available in either a 78 or 90 mm version.
The 90 mm is used in application like heads, cam, power adder applications.
Where as the 78 mm is utilized in more "minor" bolt on applications.
The cost of the 78 mm is $875.00 and the 90 mm is $962.00. The manifold
will be available for purchase in the first week of January. We are now
taking orders for the first run. If you would like to purchase one of the
LSX's, give me a buzz at (662)-224-9336.
Regards,
Old Jan 16, 2004 | 06:36 PM
  #223
8POTS's Avatar
I think you should pay the Aussie crowd a visit at www.ls1.com.au...we're a nice bunch There are some very switched on people there who can go right into it for you.
The HSV GTS300 is different in that it has has a massage by Callaway there in the US...heads , cam etc...the MAFless tune for it was coded here by HSV. The LS1 edit tuners here use this code as a basis for their custom work where a customer wants a MAFless tune.
Problem may be for US owners that all your LS1s are tuned from the factory to use a MAF regardless of the car built...C5 or humble F-Body and so there is no local code for a MAFless setup. Not sure if our tune will suit your cars and I think the computers are a wee bit different from memory. Post a query on our site and see if someone like 'Delco' has an answer for you. I suspect there is a difficulty only because if it were easy to use in US computers, I'd expect to be seeing quite a few US cars sans their MAFs by now.
If your going with a 90mm TB , it might be nice to be 90mm all the way through the induction path rather than stuffing air past a 84-85mm MAF. A MAfless tune is an obvious way of removing that bottleneck.
I noticed someone above mention a 90mm 'Pro M' MAF...that might do the trick too of course....I didn't realise a 90mm MAF existed for our cars. Live and learn I guess.
But lots of people here love the MAFless tunes , no dramas running off the MAP sensor and we are a couple of years on from the first custom versions of this style of tuning Perhaps some switched on tuners there (not your 'mailorder tuners') have or are in the process of looking at 'loosing the MAF'. Dunno.
Cheers,
Brian
Old Jan 17, 2004 | 10:04 AM
  #224
Got Me SOM's Avatar
almost 25000 views on this post alone, amazing..Can you say we were eagerly awaiting results or what??!!
Old Jan 17, 2004 | 05:29 PM
  #225
Chicago Crew UnderBoss's Avatar
JEFF,
How's the FLorida life treating you brother!!! HOpe all is well. I can truly say in the middle of a Chicago winter(all be it a mild on so far) i would MUCH RATHER be in FLA right now than Chicago!!!
Anyone/THUNDER:
Any results yet from the 03 z06 with bolt ons that you were going to test today Saturday, with the LSX intake?
Old Jan 17, 2004 | 05:32 PM
  #226
Got Me SOM's Avatar
What's up! Florida life is treating me very well. Here's a pic I took two weeks ago, it was 80 degrees and everybody had their ride out. Come on out and visit sometime!
As you can see, life aint too bad...
Old Jan 17, 2004 | 05:57 PM
  #227
SCHWEEEEEEEEEEEEEEEEEEEETTTTTTTTTTTTTTTTTTTTTTTT!! !!!
Old Jan 17, 2004 | 09:55 PM
  #228
lsx24's Avatar
Nice Gains!
Old Jan 18, 2004 | 01:40 PM
  #229
Beast96Z's Avatar
There is a popular tuner here in the US that can delete the mass air and convert our cars to speed density. He actually came down to our local shop yesterday and converted a 98 TA to speed density. It is deffinatlly a process that needs to be done on the dyno, but the gains were very good.
Old Jan 18, 2004 | 08:01 PM
  #230
ALPINE's Avatar
oh really, what kind of gains
Old Jan 18, 2004 | 08:25 PM
  #231
CamaroCain's Avatar
What kind of cost to convert to speed density?? What all is needed, just programming??
Old Jan 18, 2004 | 09:23 PM
  #232
hoserack's Avatar
I'd like to see some spray #s.
Old Jan 19, 2004 | 12:00 AM
  #233
99 Black Bird T/A's Avatar
MAF less or Speed Density tunes have better throttle response. It should be simple to do a MAF less tune. I think East Side Performance has experience with exactly this sort of thing.
Old Jan 19, 2004 | 01:40 PM
  #234
PCMFORLESS's Avatar
Why are there 4 runs difference between the before and after runs instead of back to back? Also can you post the acutal run files where we can all download them and look at them with the dynojet viewer?
Old Jan 19, 2004 | 01:46 PM
  #235
SSactionLs1's Avatar
or you can buy the AEM EMS standalone PCM which is due to come out in 2 months..Mafless, built in wideband, and progressive nitrous controller.
Old Jan 19, 2004 | 03:36 PM
  #236
NicD's Avatar
7 Second Club
Since when? Last time I talked directly to AEM about this they can't get ahold of the GM PCM connectors. They do have some directly wired to the harness though for testing and they have been running the LS1 from their EMS for quite some time now. Just need the connectors.
Old Jan 19, 2004 | 09:51 PM
  #237
amwellls1's Avatar
good info keep it up guys
Old Jan 19, 2004 | 11:02 PM
  #238
rickws6's Avatar
what happened to the test they were supposed to do on a stock ZO6 sunday ?? any results ???
Old Jan 20, 2004 | 12:27 AM
  #239
BlackNite383's Avatar
I wonder what i could gain with my new setup in my sig. below? And would i be better
off with the 90mm version with the 90mm TB from FAST? When GTP gets his intakes
in, he has one set aside for me after he gets done testing it to see if it will help with my new setup. I saw it as SEMA and it looks like it has a lot of potential. Since i'll need either a 85mm or 90mm TB, maybe the intake is worth trying. I just keep thinking the 90mm intake might be alittle too big even for a 383 stroker with a 12#-15# D1SC kit. But i'll just wait til Craig from GTP calls me and gives me the scoop.
Old Jan 20, 2004 | 12:30 AM
  #240
my friend (a member here) is getting one for his zo6 in march..
