Are all poly motor mounts created equal?
Old Jun 11, 2010 | 06:47 PM
evo462's Avatar
Default Are all poly motor mounts created equal?
Is there a "better brand" or style to use when it comes to poly motor mounts? They'll be installed in a 2002 Camaro Z28. I wasn't sure if there was a more troublesome brand or something.
Thanks
Old Jun 11, 2010 | 11:34 PM
99Bluz28's Avatar
Thumbs up
Yes, Prothane engine mounts go in super easy!
NOT !, I don't think it really matters, since the install is a PAIN regardless which brand you get!
Old Jun 12, 2010 | 02:56 AM
99SSJarhead's Avatar
poly mounts are trouble regardless, buy solid mounts and save your self hours of useless work, pain, and misery.
Old Jun 12, 2010 | 07:15 AM
Adam2001WS6's Avatar
Isn't this going to be dependant on what the driver wants out of the car? Drag racing vs. daily driving?
Old Jun 12, 2010 | 10:19 AM
01ssreda4's Avatar
Thats incorrect, and just plain silly. Polys shoulda came stock on every car, they are great
Old Jun 12, 2010 | 10:52 AM
00FirebirdaREV's Avatar
Solid mounts Are going to be what I get... Even if my car shakes it's self to pieces I will still get them! Not a dd so it's not a problem
Old Jun 12, 2010 | 11:16 AM
99Bluz28's Avatar
Yeah, installing the poly mounts is a pain, but the end results were worth it!
Old Jun 12, 2010 | 11:43 AM
ha haa.
I mean install wise. I agree that they should have come standard.
Old Jun 12, 2010 | 03:29 PM
evo462's Avatar
I'm paying a shop to do it because I don't have the time (or desire) to do it myself right now. If a poly motor mount is a poly motor mount, I'll just order whatever I find at a good price then?
Old Jun 12, 2010 | 05:47 PM
Yeah, more or less find the best price and the cheapest shipping.
Old Jun 12, 2010 | 07:47 PM
jerflash's Avatar
dude once you do it you will never want to do it again. i just did mine but have not run the car yet...hardest thing i did on my car ever and i have done just about everything
Old Jun 12, 2010 | 09:53 PM
Pocket's Avatar
If poly mounts are "the hardest" then Id hate to see you do a stall swap or 4L80E install
Ive done 4 sets of polys and am about to do one for my swap. Its not too difficult, just remember to leave all the mount bolts loose until you get both of the big through bolts in. Leaving the trans mount loose also helps some
Old Jun 12, 2010 | 10:01 PM
jerflash's Avatar
dude i done heads, cams, motor swaps, tranny swaps, rear ends, full suspentions...pretty much everything you can do to these cars...all on cinder blocks in my drive way. i know how to get things done and do all my own work.
the mount swap went smooth on the passanger side...to smooth actually but when it came down to that driverside mount getting that through bolt to line up took all my energy. It was a big bitch thats all im tring to get across. for such a simple part it take awhile to get done.
Old Jun 16, 2010 | 03:22 AM
sjsingle1's Avatar
its not that hard of a install.........ya bunch of ******
Old Jun 16, 2010 | 03:52 AM
Sommer86's Avatar
I've heard that Energy Suspensions Poly motor mounts are slightly softer than Prothanes. I personally used Prothane. It's the most common out there.
Old Jun 16, 2010 | 06:03 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
If you do motor mounts when you're doing headers, it's really not that tough. You don't have to remove anything else on the driver's side, and the passenger side requires you to simply unbolt the a/c compressor.
Plan your work wisely, and do the mounts when you do headers and you save yourself the headache of "why is my ypipe banging the floor boards".
Old Jun 16, 2010 | 06:57 AM
Pro_built7's Avatar
NO THEY ARE NOT !
do NOT get energy suspension, I installed those and they were loose inside the clamshells, didn't fit well and were an incredible PITA !. I ended up doing it twice
I went prothane, and have used them on two seperate cars now, and they kick ***. They fit tight in the clamshell not that difficult to install etc....
I'm telling you man, get prothane (ask me how I know lol).
Old Jun 16, 2010 | 06:58 AM
Pro_built7's Avatar
This.
energy suspension mounts= Fail. (from experience)
Old Jul 13, 2018 | 10:05 PM
Cole Train's Avatar
idk how your energy suspension mounts flopped in the clamshell... The ones i got were snug as **** in the clamshell and don't budge...
Old Jul 13, 2018 | 10:29 PM
You are responding to an 8-year old post...
