HELP!!! What does this hose connect to?
Old Jun 13, 2010 | 10:16 AM
MikeG's Avatar
Default HELP!!! What does this hose connect to?
Hey guys I'm finishing up a cam install and have a hose coming off the radiator left over and can't figure out where it hooks up...help!
Its the one that hooks up to the radiator with that copper line in the second pic
Attached Thumbnails HELP!!! What does this hose connect to?-hose-001.jpg   HELP!!! What does this hose connect to?-hose-002.jpg
Old Jun 13, 2010 | 10:22 AM
99427camaro's Avatar
that goes under the throttle body to the cross over pipe
Old Jun 13, 2010 | 10:29 AM
MikeG's Avatar
Nope, that one is already hooked up. The hard rusty metal line points downward and there is no way it could reach up to the TB
Old Jun 13, 2010 | 10:46 AM
ow **** you sure that is not a trans cooler line should hook up under you crank pully
Old Jun 13, 2010 | 10:54 AM
MikeG's Avatar
Well I have an aftermarket tranny cooler. I was thinking that's what it could be...The lines are all hooked up still I didn't disconnect them. Now I get it. that hose is bypassed by my B&M cooler.
Old Jun 13, 2010 | 11:05 AM
even if you have an after market cooler you should run your trans fluid through you radiator in case you stuck in traffic your trans will still get cooled by your coolant
Old Jun 13, 2010 | 01:40 PM
Arc00TA's Avatar
Although it never works like that. The trans fluid just gets hotter and hotter. Anyways, that the upper trans cooler line. If you're using an aftermarket one I would just plug that so it doesn't get crap in there.
