For those who bought 90mm FAST intakes
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by Beast96Z
It's already tight enough with the TNT power coupler, so there is no room for another adaptor. I'll pay the $500, just wish they would hurry since false claims were made.
you are not getting a TNT power ring on a 90mm TB..... think about it
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
LS1Tech Premium Sponsor
We are going to test a ls6 heads cam car, add Fast intake and then bolt on the 85mm maf & lid setup to see if that helps to provide more power. I really would like to try a tpis intake also...
Jason
Jason
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Jason
Jason
As for the power coupler, I know it won't go on the 90mm TB.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
Yeah, Harlan has a 90mm PRO-M MAF.
It'd be nice if we could go with a mass air density program instead of a mass airflow config.
Originally Posted by P Mack
Someone had a huge maf in the FI section a while ago. It was like 100mm or something. I'd like to see what one of those things would do with this intake.
I'll be severly pissed, since I was told the stock throttle body WOULD bolt up. Not to mention you need a 90mm throttle body gasket.
Tom
![](http://www.tbyrne.com/Banners/camarobanner.gif)
T BYRNE MOTORSPORTS
E-mail - tbyrne@tbyrne.com
Order line 1-877-4-TBYRNE
SUPERCHARGER DISCOUNTS AVAILABLE!
Originally Posted by JohnnyStorm
Beasty, where did this Tuner hook up a speed density sensor and how would it hook up to the PCM? Just curious.
