Worth it to swap?
Old Jan 15, 2004 | 09:34 PM
BLUEBYU's Avatar
Default Worth it to swap?
I currently have a Granatelli which I believe is 78mm. I am not sure what the advantage of having a "calibrated" maf would be if I have the ability to tune using Edit????? I am contemplating having Mark swap a 85mm on the dyno to see. Are there any experiences out there? One more thing, what is the difference between the SLP 85mm and a '02 Z06 maf?
Thanks.
Old Jan 15, 2004 | 09:39 PM
WS6FirebirdTA00's Avatar
the slp maf is **** thats what the problem is. well they calibrate it apparently for our cars or something. dont get it u will run lean as hell. i saw were only 5 hp was given from an 85mm over stock. and a ported one actually put out 2 more hp than the 85
