How do I change the alternator pulley?
Old Jun 20, 2010 | 11:47 PM
transsam's Avatar
Default How do I change the alternator pulley?
I have been running crank pulley, and will be adding some electronic drain (1200 RMS amps, and HIDs on my fogs and low beams). I bought the new alternator pulley like a year ago, and I even have the belt (okay, 4 belts - what can I say, they were $1.49 each on amazon. I couldn't resist).
Anywho...
How do I change the actual pulley? I am afraid of sticking a screwdriver to stop the blades, I don't want bend or break any of them and they are pretty thin. What have you folks had to do?
Old Jun 21, 2010 | 12:43 AM
NeedaV8foundation's Avatar
stick a air socket on there and itll come right off
Old Jun 21, 2010 | 06:19 AM
crainholio's Avatar
Originally Posted by transsam
(random navel gazing redacted)
Anywho...
Impact gun @ 80psi gets it done.
Next you'll post that you don't have one, is there some other way, blah blah blah...
Old Jun 21, 2010 | 08:02 AM
Gatsby's Avatar
Impact gun takes about 1 second to get it off/on.
Otherwise you need to use an allenhead wrench and stick it in that hole on the front to keep it from turning and a wrench to get the actual nut off.
Old Jun 21, 2010 | 09:12 AM
shane2390's Avatar
Yea, what they said, most cars use a 24mm socket
Old Jun 21, 2010 | 09:40 AM
transsam's Avatar
Where the hell did that come from you don't build a car like mine without one! Go be an *** to someone else! Christ man.
Old Jun 21, 2010 | 11:52 AM
01ssreda4's Avatar
Have you considered that although the bigger pulley may produce more amps at idle you may be over-revving the alt at WOT conditions?
Old Jun 21, 2010 | 12:05 PM
crainholio's Avatar
You assembled your engine with a pneumatic impact gun?
I suppose a lot of people that have an impact gun, staring at the alternator pulley nut, would have put 2 and 2 together...
Old Jun 21, 2010 | 12:14 PM
bayer-z28's Avatar
Impact gun and a leather welding glove.
Old Jun 21, 2010 | 01:32 PM
transsam's Avatar
I've got the small pulley on the engine, so I am technically under-revving the alternator at all times. This is to just bring it back to, or close to stock on the alternator.
Old Jun 21, 2010 | 01:37 PM
01ssreda4's Avatar
^^^I see.
Old Jun 22, 2010 | 11:14 AM
Gatsby's Avatar
Isn't there some sort of "overrun" clutch in the alternator? Or was i misinformed? I didn't know you could over-rev an alternator.
Very interesting.
