soild engine mounts? advise needed!
Old Jun 23, 2010 | 01:50 AM
BFarrier's Avatar
Default soild engine mounts? advise needed!
i want to run soild engine mounts with a poly trans mount. what are the pros and cons i dont care about the vibration either. i hear that poly trans can crack the housing and soild engine can score the cyclinders? is that correct? im only around 400rwhp and going to do longtubes and a larger cam soon.. advise needed thanks
Old Jun 23, 2010 | 01:54 AM
BFarrier's Avatar
i dont know if im in the right forum for this question either. apoligize if thats the case
Old Jun 23, 2010 | 02:20 AM
Arc00TA's Avatar
I've never heard anything about solid mounts, and poly trans mount will only hurt it if the motor mounts are softer. I.E. rubber motor mounts with poly trans mount, causing too much stress on the transmission.
I ran the combo you are looking at for 2 years with 400+ rwhp and never had an issue. Vibrations were not bad either.
Old Jun 23, 2010 | 03:00 AM
BFarrier's Avatar
thanks for the imput are recomendations of brands for soild mounts?
Old Jun 23, 2010 | 03:01 AM
BFarrier's Avatar
*any brands i should stay away from?
Old Jun 23, 2010 | 11:24 AM
Arc00TA's Avatar
I had spohn they were real nice quality. Don't think I've heard of some bad ones.
Old Jun 23, 2010 | 11:47 AM
Aetos's Avatar
I'm running solid MM and a poly mount on my M6. I love it! The vibrations are not really noticeable, I actually like the small amount of vibrations the solids have added to the car.
Plus, no more engine movement, all the power transfers to the drive train now
Go towards the end of this video and there is an engine bay shot(my car):
http://www.youtube.com/watch?v=uvnBKqWAlHY
Old Jun 23, 2010 | 12:33 PM
dgcustomz's Avatar
I have been using spohn solids for over 2 years now and I love them. I have never had any problems and I am also using a poly trans mount.
 Michael S. Palmer
Old Jun 24, 2010 | 07:09 AM
KurtRardin's Avatar
Veteran: Marine Corps
I've got poly engine mounts and I think that if I were doing it over I'd probably go with solid mounts just to free up some weight. The vibrations associated with poly engine mounts aren't even worth commenting on, but I had a BAD vibration with a poly trans mount. I'm talking about being able to watch coins walk across the carpet at like 55mph. I'm pretty sure there was a "WTF?" light that came on in the dash.
The rubber mount went back in and I'm happy once again.
Old Jun 25, 2010 | 01:06 PM
Magic Man's Avatar
I also have had Spohn's and poly tranny mount for years with no problems nor do I really notice it.But each to their own.
Old Jun 27, 2010 | 02:32 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
same here
Old Jun 27, 2010 | 03:14 PM
velox65's Avatar
spohns and poly trans here as well in my DD, didnt notice much of a vibration difference but did notice more power getting to the wheel's according to the ole'butt dyno
Old Jun 27, 2010 | 11:00 PM
sjsingle1's Avatar
i prefer poly MM myself
Old Jun 27, 2010 | 11:16 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
More importantly: How are you making 400rwhp without a cam and longtubes through a posi?
Old Jun 28, 2010 | 01:54 PM
Z28/2002's Avatar
must be due to "all SLP options"
