CAI vs Filter directly to TB
Old Jun 23, 2010 | 02:40 PM
Mustang605's Avatar
Default CAI vs Filter directly to TB
whats the difference between running a cold air intake vs just bolting the cone filter rite to the throttle body?
Old Jun 23, 2010 | 03:21 PM
Nemesis350's Avatar
well with the cold air intake you're taking the outside air, which should be much colder than the 200 degree heat from under the engine bay allowing for a much denser charge, and keeping it from soaking too much heat. A filter directly on the throttle body... well you're making your engine breath all the hot air from under the engine bay killing a surprising amount of hp. Plus unless you change your setup, you'll needs your maf provisions and other stuff.
