hooker vs pace vs macs
as far as the kmember goes that 30 seconds it takes to cut an 1/8in off in my eyes is worth the $120 i saved by purchasing pacesetters instead of hookers Trending Topics
I have heard from lots of people to just keep the macs that it isn't worth the money to switch over to a longtube, but I still hear the other side that says the LT's will make more power, but how much is the question.
So does anyone have a graph of macs vs. any longtube given the same heads/cam combo?
run 38 is Grott headers, FMS 3" Y-pipw and hooker exh, you can see its a little richer with the LTs and there is an excellent under peak power gain.
Track results, same track one week apart, similar DA, 12.08 @ 116 (1.740 60') MACs, 11.86 @ 117.5 with a 1.727 60' Made me a believer in LTs. But then again I have MACs again on the car - they were here and free
. the macs put out alot better then i thought. good info
. Also the new Flowtech LTs (similar to the Hooker/Jet Hots supposedly) should be added to the list.
there is not a single header out there that hasnt caused someone to grind the block. Which btw is a 13 second mod. There is not a single header out there that has not caused someone to grind the K member. Which might i add is another 13 second mod. Dyno wise we all know the ls1/6 is a very non consistant motor as far as #'s go. LT should make more power.
Macs are nice mid length headers. They are not carb legal and these days you can get LT cheaper. Some LT (pacesetters) even have MORE ground clearance.
P R E F E R E N C E
P R E F E R E N C E
