Ok to get pacesetters?
Old Jan 18, 2004 | 12:05 PM
99-LS1-SS's Avatar
STF Veteran
I just put my Pacesetters on last night. The headers went in without too much trouble. Had a little trouble on the drivers side. I also had to notch the k member just a little. Had to drop the starter. As far as the y-pipe goes. My brother and I cut it apart before we ever hooked it up. The way they made the pipe is pretty sorry. I restricts flow on one side. Someone on here has a picture of what I am talking about. Anyway I cut the y-pipe apart and cleaned the inside up and fit it up under the car and tack welded it. So that was what I had to do to get mine to work. FWI, My car went from having Hooker shorties with a SLP y-pipe(with cats) to Pacesetters with their y-pipe(no cats) that I had to modify. I noticed a little difference in power and a LOT louder. My car is a A4 with a mild converter. I can spin the tires through first and almost completely through second. All in all I would recommend the Pacesetters and have someone make you a y-pipe. Good luck.
Old Jan 18, 2004 | 12:33 PM
samz28's Avatar
I am getting knock on the floorboard from what i guess is the ORY. I also noticed flashing SES light when i was idling at mcdonalds this morning and it was knock knock knocking the floor board.
Gotta find a solution to this problem.. I'd advise folks that this kinda sucks , i know i got an american car, but damn the SES light shouldn't go off because of the headers. Maybe i need some new mounts 70K miles, i dunno. They hung a 2x4 over the ory and took 4 men to hang off it while hot to help angle it down.
I do notice some engine movement at idle. Maybe my mounts are shot. Trans definitely needs poly.
Any tips from fellow pacesetting folks..
video of engine movement..
http://home.test-afl.homecom.com/sbr...ro/camaro2.wmv
Old Jan 18, 2004 | 04:27 PM
WS6FirebirdTA00's Avatar
yeah my mounts were shot at 40k miles, both tranny and motor mounts. i put poly and the motor doesnt really move. with the k member not notched it rarely hit and it was real damn close. i bet this will help u a lot
Old Jan 19, 2004 | 12:42 PM
JHarmon's Avatar
The headers are a great value. The Y pipe is a total POS. Either have a custom Y made or go with duals. BTW, I have a set of 2.5" mandrel bent duals(new) with X pipe for sale for $350. Email jeffharmon70@hotmail.com if interested.
Old Jan 19, 2004 | 12:51 PM
Magyver's Avatar
My car is lowered and I just love to see tips on cars, but I love the sound of true duals.
Old Jan 19, 2004 | 12:59 PM
99-LS1-SS's Avatar
STF Veteran
I have seen guys run duels out the back. You can do it if you want to.
Old Jan 19, 2004 | 04:03 PM
samz28's Avatar
So your true duals replace my hooker catback?
How loud? lol.
Btw i believe the pacesetter LT may be hitting the k member.
Take a look at my idle video here. Is this excessive motor movement at idle?
Old Jan 19, 2004 | 06:32 PM
looks like its moving a lot there at the beginning. mijne doesnt move at all, even when i pop the throttle, the whole car moves lol
Old Jan 20, 2004 | 07:44 AM
samz28's Avatar
i figured the 224/226 .570/.571 112lsa cam would make it shake a little. You think i need new motor mounts?
Old Jan 20, 2004 | 08:10 AM
No Juice's Avatar
Does anyone have pictures of their y-pipe?
Old Jan 20, 2004 | 01:45 PM
samz28's Avatar
It's not pretty. You don't want to see it. It was designed to not scrape on speedbumps, but rather to smack floorboard. The Y collector was welded by illegals i think, or high school students. I'm really dissatisfied with my setup.
Even Texas-speed said they had a ton of people complaining about both K MEMBER hitting and floorboard hitting.
I wish i had spent a few hundred more on better headers now.. Save a buck spend a bunch.
Old Jan 21, 2004 | 05:52 PM
  #32
Magyver's Avatar
Y pipe and headers are too different items. A custom made y pipe is what you needed.
Old Jan 21, 2004 | 07:19 PM
  #33
samz28's Avatar
or you could just buy a system that fits
