Who's used a manual pipe expander for exhaust work?
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I plan on buying a pipe expander like this,
and was wondering how well it works? I'm going to be expanding 3" pipe for duals and wondered if it's going to be a beast to expand the pipes so I can slip fit them together, or if it works well with a regular wrench, wratchet?
![](http://static.summitracing.com/global/images/prod/norm/sum-900662_m.jpg)
The pipe expanders are made to take the clamp indents out of pipe and to reshape the opening, not to enlarge pipe. It can be done but requires a heavy duty expander and a good deal of time, patience and preferably - heat.
And they really only work on thin walled tubing. That thing doesn't work very well at all on a good quality stainless steel catback pipe. I have one from harbor freight, and I use it occasionally, but I do know its limits.
If you need a piece of pipe flared, take it to your local Midas. Slide the guy 5 bucks and it's a done deal.
(been there, done that)
-Andrew
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
-Andrew
It worked well for me. I rented it from an auto parts store (forget which one), but I ended up buying it from them.
The thing is though, you need an air compressor to use it. I couldn't imagine trying to manually expand a pipe with it. Someone mentioned that they break, well the only thing that can break are the rubber o-rings that hold it together. I did break one of the o-rings, but you can pick those up anywhere. It's one of those tools that makes you happy when you need it, but you might not need it that often.
