Headers installed. Now how to keep headers from hitting floor and ratlling?
You asked for peoples thoughts, now that you have it do with it what you will.
Stock motor mounts were not designed for LT's and let the motor move too much.
The first set I helped do, we left the Passenger side Header in place, but we had to remove the Driverside. Thankfully none of the rest of the exhuast was on the car, so it wasn't that big a deal to get the driverside out.
The following two Poly MM Installs we did with both manifolds off the car. And although, it was still a bitch to get the holes lined up for the long bolts, this method was way easier than having the header installed.
I guess if the O.P. is feeling lucky he could give it a shot.
Best of luck.
Best of luck.
Anyway.... OP you are going to have to realize that the stock mounts are far crappier than you want to believe lol, and allow the engine to move a lot which moves the exhaust a lot. And for what its worth I love my poly mounts, I thought I would notice a horrible idle vibration etc... but I dont notice them at all its actually smoother. BUT I did have completely shot stock mounts and I have dumped duals so I already have plenty of vibration.
Also OP I can almost garuntee that after this many years the engine is leaning down on the passenger side and when you hit the gas the motor is twisting and letting the driver side header hit the body of the car.
If you could get under the car while up in the air you could compare the oil pan to the K member and probably see the engine lean a little over to the passenger side, I could definately see it on mine before the mounts, after it sits level again and no more floor banging.
If its the y pipe hitting, mark where its hitting, take it off and put a dent in it with a hammer.
Saves you lots of time, money, and headaches.
If you wanna spend the money and waste another several hours changing motor mounts where a simple dimple/dent will take care of the same problem, be my guest.
