Headers installed. Now how to keep headers from hitting floor and ratlling?
I'm guessing your having this problem because your on stock motor mounts???
If so a set of poly mounts will most likely fix your problem.
Nor any of my friends that I've worked on.
Poly motor mounts wont let near as much movement occur over new oem ones.
I'm sure your 11 year old rubber mounts are not helping anything.
If is the mounts allowing the motor to move and exhaust to hit then you might think about how much stress your going to put on that exhaust if your bolting it in place and not letting it move.
Anyways, to the OP, swap to Poly mounts or solids and I bet your problem disappears... Don't use a chunk of rubber or rig it up in another way. Just do it right and you'll be happier.
Your problem is either A: you have poor quality/fitting headers, or B: the mounts are flexing too much and letting the exhaust hit. I had issues with this before I went to poly mounts, but it was only under full throttle. When idling etc clearance was fine with my Hooker headers. The problem is actually more likely to be the Y pipe hitting the frame rail under the driver seat area. The clearance there is very tight on most setups, I have a Lane's True dual setup, its the only setup I have seen that makes clearance in the pipe right in that area by ovaling the pipe.
And with stock engine mounts the engine moves A LOT... A lot more than you think it does. Even if the mounts were brand spankin new, they are rubber and soft so they move a lot non dependant on age or mileage. Get poly motor mounts and never look back.
Upgrade your Motor Mounts to either a set of Polys or Solids and the rattling and banging of the exhaust will be gone.
This should be done with EVERY INITIAL INSTALLATION OF LONGTUBE HEADERS.
I hate to tell you this, but I hope you enjoyed your LT Installation. In order to gain the necessary amount of room to remove and reinstall the mounts, you will pretty much need to completely remove your new Y-pipe and Pacesetters. And once you've completed fighting the new mounts into place, you can reinstall the exhaust.
Here is the writeup I followed when I did (or helped do) the mounts in my bro's 02 SS, my 99 Firebird, and a friend's 98 Z28...
https://ls1tech.com/forums/generatio...r-written.html
Don't get me wrong. Installing Motor Mounts in these cars is a pain in the ***, but this writeup is great for letting you know what to expect. That kinda helps to dull the pain. LOL
Seriously though. Upgraded motor mounts are the solution to this problem. Anything else is just a remedy.
Good luck, man.
Good luck, man.
