Why Does My Trans Am Run On The Hotter Side?
so we thought head gaskets.
then the heads came off and sure enough it had 2 blown head gaskets
have you even thought it could be them?
you should not have your fans on cruising above 35 and the temps should be alot lower...
maybe time to pull the ac haha...the hottest I ever get is 195 and that is stop and go traffic and I do not even have the bottom plastic air deflector on the car anymore...something up man my guess would be the thermo not opening all the way or dirty cond/rad...
let me know if you figure it out...you can always pull the ram air to rule that out too...
Want to lend me a hand
LO is set to go on at 190, off at 180.. HIGH is set to go on at 210 and off at 200. So if my car never gets below 180 my LO will always be on..
The passenger side head is on the suction side of the water pump making the coolant cooler when it hits the aftermarket sensor. So my water temperature gague is reading correctly. Yesterday it was about 84ºF outside, my aftermarket water temp gague was reading about 185ºF.
Now the drivers side head is on the discharge side, so the coolant gets heated up before it gets to the head and reads higher. Hence why my LO fan is on the majority of the time. And we know the sensor for the fans on the drivers side head is what sends a signal to the PCM to turn the fans on.
So there is my 35ºF temperature difference. And according to my buddies aftermarket water temp gague and chrs1313 aftermarket water temp gague mine is reading correct
And I challenge you all to see when your fans are running. If you have gotten the tuned to come on earlier you will see..
So for me my LO comes on at 190ºF and turns off at 180ºF.. My HI turns on at 210ºF and off at 200ºF
LO= both fans spinning (1 speed)
HI= both fans spinning (2 speed)
