D585 coils - necessity of changing dwell tables?
How necessary is it to change the tables?
I don't have a tuner of my own and have a pack dying.. Thinking about replacing all my packs to these...
i also put in the d585 coils without changes for the tune. i'm honestly not sure who much of a difference it has made AS IS, but it seems to run nicer
But when i get dyno tuned i will probably have the dwell tables checked in case it helps any.
I do believe there is already a lengthy thread here with charts showing differences in the variety of coils that'll work with our cars, including aftermarket brands.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Kleeborp the Moderator™
http://www.megamanual.com/seq/coils.htm
https://ls1tech.com/forums/generatio...p-18-6-tq.html
https://ls1tech.com/forums/generatio...ke-sticky.html
Keep in mind that this is a very polarized issue - there are those that say this is a complete waste of time and money, and others that think they are worth it. If you have a coil pack going south, it might be worth looking into. There is no doubt that they are more powerful coils, but their necessity in this application remains to be seen.
FWIW, I run them on mine with a modded dwell table that doesn't match anything remotely close to the stock LS1 coil table OR the stock D585 table.
You should use the correct dwell table.
I have an D585 vehicles OEM tune file if you want the correct dwell table. Its in HPTuners format. Its posted here;
http://www.hptuners.com/forum/showthread.php?t=13159
You could go with the argument that GM's engineers set the dwell tables up for maximum longevity, and you'd probably have a pretty decent argument if that's what you chose to believe. The D585 and LS1 coil dwell tables are definitely different...see below.
I went off of that Megasquirt link I posted above where they found that the maximum dwell time for the D585 type of coil was around 5.0ms @ 14V - any more dwell didn't generate any more spark energy, so it would probably just heat up the coil (although they do have heat sinks, so they might handle it better). I just massaged the table for mine so that the maximum value was 5.5ms @ 12V, 5.0ms @ 14V, and so on (as seen in the table in that link I mentioned), and whatever it took to get there, I just added to the rest of the values all across that row. A little linear interpolation, and you get the randomness that is my current dwell table. It might be a little high on dwell in the upper RPMs, but I'm not sure...after all, I could ask it to charge for a lot longer, but it will only charge as long as it can before it has to fire under those conditions.
Stock LS1 coil dwell table:
![](http://i305.photobucket.com/albums/nn227/meentss02/StockLS1CoilDwell.jpg)
Stock D585 coil dwell table:
![](http://i305.photobucket.com/albums/nn227/meentss02/StockD585CoilDwell.jpg)
And what I currently run:
![](http://i305.photobucket.com/albums/nn227/meentss02/CurrentDwellTable.jpg)
