!AIR. necessary to remove air pump?
Old Jan 19, 2004 | 03:28 PM
bigMAC's Avatar
Default !AIR. necessary to remove air pump?
do i need to remove the air pump or can i just take off the hoses and remove the air fuse so it doesn't go on? Is there an electrical connector i need to take off the air pump if i am still leaving it there?
Old Jan 19, 2004 | 06:50 PM
WILWAXU's Avatar
you don't have to remove the pump. But it takes less than 15 mins to remove.
Old Jan 19, 2004 | 07:08 PM
Damian's Avatar
LSX Mechanic
You can do it either way. Removing the pump saves 6-7 lbs or so off the front end...
Really easy to remove. Right behind the driver's side foglight is where the pump is. Unbolt that flap there, and you'll see it. Takes 10 minutes..
You'll throw an SES code for it, but it doesn't hurt performance at all. I removed my AIR pump like the first week I had my car 4 yrs ago
Josh
Old Jan 19, 2004 | 07:17 PM
ss rally red's Avatar
Might not even turn on the SES light, had mine off/disconected for 3 months before I had edit done and it never set a code. Take out the pump and see how far you can punt it.
Old Jan 19, 2004 | 07:30 PM
Bad Blu Formula's Avatar
I wouldn't recommend removing the pump if you still have cats. If you're going to have an ORY with your coming pacesetters then go ahead and do it when you get them.
Old Jan 19, 2004 | 07:33 PM
superchannelkev's Avatar
an article on installuniversity.com said it will not throw a code and has detailed info about removing it
Old Jan 19, 2004 | 07:59 PM
cueball's Avatar
sorry about going off the topic, SUPERCHANNLEKEV where did you get your front pro beam head lights, are they HID head light?
they look awsome man!
Old Jan 19, 2004 | 08:33 PM
mcflyz28's Avatar
Blocked off my air pipes and it thru a code in 15 minutes, it's all disonnected and removed now except the air pump is still in and defused.
