Will these catalytic converters work?
Old Jan 20, 2004 | 10:49 AM
BlkBrdWS6's Avatar
Default Will these catalytic converters work?
Hey guys! I'm trying to find some high flow cats to use in making a custom Y pipe for my pacesetter LTs. What dimensions should I look for? I found these on ebay, can I get these to work with a custom Y pipe connected to Pacesetter LTs? Thanks a lot guys!
Here is the link.http://cgi.ebay.com/ebaymotors/ws/eB...tem=2455485039
Old Jan 20, 2004 | 11:05 AM
z28hokie's Avatar
I bought my cats from the same guy- for the same purpose (custom Y). Give him a call or e-mail. I got a pair of oval, 3" (no AIR fitting- since ours is on the headers) cats- for $112, shipped.
I believe the pacesetters have a 3" collector- so I'd get 3" oval cats.
Old Jan 20, 2004 | 08:24 PM
cm02WS6's Avatar
Those will work. You might want to consider the 941xx series, as they are a shorter version of the 94xxx series. Your choice of 2.5" or 3" will depend on your tubing selection and where you want to do the reduction. Carsound and Magnaflow are the same, so check this out and you will save a little:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2446372447
www.magnaflow.com lists all the configurations and part numbers for their converters.
