How many people's ORY hits the floorboard?
STF Veteran
I probably have about 1/8 of an inch. I am pretty sure that is what is hitting. Where my collector and my header meet together underneath I have about 1/2 of an inch. Is that enough?
Try getting some thick rubber, like the elastic bands that you use to hold items down to the back of a truck and cut about a 2 inch piece. Crawl under your car and JB weld the rubber piece to the floorboard where you see little clearance. It will more than likely be a little before your Y-pipe bends on the driver's side. This fixed my Y-pipe banging blues.
Originally Posted by NiceTry
if you don't want to weld for even if it hits after being welded, get a big hose clamp or something similar and put a piece of heater hose around it then clamp it around the y-pipe between it and were it hits the floor board.
![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
my ory is nailing the drivers floorboard. For the ghetto till i get it done right fix. i used a crowbar and put a valve spring (dont laff) in between. Now i only get k-member knock on WOT instead of alot of part throttle knock (floorboard) crappy *** pacesetter junk. Ordered a poly trans mount. maybe it will help some.
